Headlight Issue
Old Mar 24, 2009 | 12:19 PM
Semiazas's Avatar
The Dark Carnival
Angry Headlight Issue
Hey guys my headlight was brutally hit by a flying piece of trash on I95 while racing and it cracked it and water got inside over a couple 2 weeks or so. Today i removed the bumper and the light and fixed it and since it got water the headlight Low beam wouldn't work. Once i cleaned it out and reinstalled it the light was turning on so i put the bumper back on and moved the car from driveway to street and now the light wont turn on anymore. Any possible fixes or anything i should look for im going to remove the light again tmrw and check all the connections bu everything looked fine upon removal.
Thanks in Advance.
Old Mar 24, 2009 | 02:09 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
hmmmmmm.... did you win.. . ?
well, the light worked after you did your fix. But if the seals aren't good, that could be affecting the light, never having messed too much with my headlights for this reason I am not 100% on this.
But I would start with making sure all your wires are tight. Something may have slipped off when you putting the bumper back on.
Get a voltage/circuit tester and work your way back from the light.
Old Mar 24, 2009 | 02:38 PM
mkztg's Avatar
:( traded in my 8
Sounds like a loose wire somewhere - trust me - I had a loose wire in my throttle body sensor harness and it took forever to figure that one out.
Start with checking the wire connections/harness
mkztg
Old Mar 24, 2009 | 02:40 PM
+1 to loose wire somewhere.
Old Mar 24, 2009 | 02:44 PM
DOMINION's Avatar
I don't buy Kool-Aid
If its cracked why not as the dealer to replace it? I would. Never hurts to ask.
Old Mar 24, 2009 | 02:48 PM
Socket7's Avatar
ಠ_ಠ
I'm sure they cover all those racing related damages under warranty. Just tell them you were playing "2 fast 2 furious"
Old Mar 24, 2009 | 03:15 PM
DOMINION's Avatar
Dont have to know you where racing, he could have been driving fast and killed a cat or hit a dear. Would they cover it then? IDK. Ask and find out.
Old Mar 24, 2009 | 04:12 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
A dear what? Dear grandma? You bastard!!
BANZ HIM!
Old Mar 28, 2009 | 11:50 AM
Semiazas's Avatar
The Dark Carnival
Ok update on the situation... I once again did the same procedure to check it but this time i opended the electrical box on the headlight you know the one that says 25000 volts Death Ahead sticker. Well anyways one of the blue cylinder thingys has rusted on a connections and ruined it now i need a new assembly as well as the headlight box electrical device.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
WranglerFan
Nov 5, 2017 09:35 AM
Randolph Alvarez
May 30, 2016 01:08 AM
tgaffner
Sep 7, 2015 08:49 PM
