Trunk Water Leak
Old Mar 21, 2009 | 05:21 PM
Semiazas's Avatar
The Dark Carnival
Angry Trunk Water Leak
I have water leaking in my trunk during raining days and maybe when i wash it. Im not sure where its comming from but i had to remove that little tool holder thing in the floor of our cars using the 10mm as a drain bolt for now. But i need some more suggestions on maybe where the leak could be comming from.
Old Dec 30, 2010 | 07:12 AM
Jimboaleeno's Avatar
Hi mate, i have the same problem here on my UK model. It appears that it could be a couple of things.
1 Rear light seals.
2. If you have a sun roof like mine then there are drain pipes. If these are blocked then water can run into the boot. (Trunk).
I have got laods of water in mine and im going to have to take a full day to check this out. Pleae let me know if you have any other ideas any one!
link http://www.rx8ownersclub.co.uk/forum...488236#p488236
link https://www.rx8club.com/rx-8-discussion-3/leaking-trunk-wet-carpet-its-mystery-113435/
Old Dec 30, 2010 | 08:23 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
read through this, it might help.
https://www.rx8club.com/showthread.php?t=113435
Jimbo has already seen this thread.
Old Dec 30, 2010 | 05:09 PM
DocBeech's Avatar
I drive at Red Line.
I hope the jute under your carpet doesn't mold!!!
Old Dec 30, 2010 | 05:22 PM
VashGS's Avatar
Zoom Zoom Addict
Does it have a wing? The holes get corroded for dealer installed wings cause they cut thru the galvanization of the body. The whole body is dipped before paint robots. But once you cut the metal the rust start eating there. Make sure your drain holes are not clogged too.
Old Dec 30, 2010 | 05:39 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
I had this when I put my cf trunk on and I simply aluminum taped (both sides) the hole on the inside rimmed left hand side over the tail light, a pic, hope this helps, it worked for me.
edit- or it could be one of the rubber ventilation flaps behind the rear fender (behind the carpet)
//last winter i got some ice buildup there and all kinds of water splashed in
///or it could be the obvious, the tail light gasket not sealing properly.
I've fixed all of the above problems and now have been clean for over 7 months.
Old Dec 30, 2010 | 05:50 PM
Thanks very much for your help. What are the holes that you have taped used for?
Im trying to see if the drain pipes from the sunroof are blocked. The trouble is that i cant find them?
Cheers
Old Dec 30, 2010 | 06:15 PM
Hi Vash,
it does have a small lip on the trunk lid. We call it a spoiler in uk. I didnt get the car from new so i will check this thanks.
Can you explain where the drain holes are and what they are for? Sorry to sound like a complete idiot but only had the car recently.
Many thanks
Old Dec 30, 2010 | 06:16 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
Cheers
There is only one hole that I taped and I don't know what it is for, but it was the culprit of my soggy trunk woes.
...i don't have a sunroof.
Old Dec 30, 2010 | 06:20 PM
Mazurfer's Avatar
Cheers
This post may help for the location and how to deal with it!
https://www.rx8club.com/showthread.p...64956#poststop
At least it will help you locate them!
Since we are talking in the rear, it looks to be right behind the wheel well. I know that the A/C condensation drain which has "duck lips" and is located in the front fire wall can get sticky and one must massage the "duck lips", so this appears it may be similar in nature?????
Old Dec 30, 2010 | 06:28 PM
Hi Maz, thanks for your help. looks quiet a job so i hope its not the sunroof. Will put ome sealer around the tail light first.
Happy New Year! Fingers crosses a dry one.
Old Dec 30, 2010 | 06:41 PM
Mazurfer's Avatar
Look at the pics in my post below real close.
Might be able to stick a thin piece of wire in from the bottom and see if any obstruction, or maybe even knock it loose?
Old Dec 30, 2010 | 06:46 PM
Cheers for advice Chad, glad it worked for you.
I would try to find out what the hole i as it could mean that water is building up in the rear of the car or some where else.
Old Dec 30, 2010 | 07:16 PM
Grace_Excel's Avatar
Charles Bundy
THANK YOU for reviving this thread. I did a lot of search last week and for some reason nothing came up. I had this problem when California had the eight day rain storm. I do have a sunroof but no rear wing, I'll read up on the links in this thread later.
Old Dec 30, 2010 | 09:21 PM
DocBeech's Avatar
while your at it make sure the seal on your sunroof doesn't need to be replaced. High amounts of UV can damage and crack them among other things. Its your opportunity to clean that bad boy up and make sure all is well.
For those of you who did get leaks and water in the car this part is very important. You either have to pull all the carpet out and dry it out perfectly, or you will need to steam clean everything. Make sure nothing gets a chance to mold! once it does you have to replace everything to prevent future problems! let it air dry out and then steam clean it, and let it dry completely all windows open for 3 days!!!
Old Jan 4, 2011 | 08:50 PM
Charles Bundy
Besides the seals in my tail lights, I couldn't find the culprit for the water leak in my trunk but the weatherstrips. Water overflowed in the gutter and went in through the break on the stripping.
Old Jan 4, 2011 | 09:19 PM
DocBeech's Avatar
car cover investment?
cliffkemp
Dec 24, 2024 10:48 AM
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
DG07
Sep 28, 2015 10:58 AM
GK1707
Sep 27, 2015 07:33 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
