DAMMIT! chopped a fuel pump wire!!!
Old Mar 21, 2009 | 02:44 AM
cfm251's Avatar
Well I am sad to say I am facing issues once again, I was in the process of replacing my fuel pump when i snapped an electrical wire that connects into the fuel pump the one that goes deep into the fuel tank, the red and black wire pair with the connector that connects to the bottom of upper part of the fuel pump assembly . The issue here is I tough simple crimping the wires into a connector would do, but i realized this wire would be somewhat exposed nonetheless and i believe at some point partially submerged in gas. Hope I am being clear enough How can I fix this, i was thinking of using liquid rubber, but i don't know how effective or lasting that will be when in contact with gasoline. If anyone knows how to fix it no problem, but if a part is necessary I would like to know which part is it, how do i go about replacing it, and where to buy it from
Old Mar 21, 2009 | 02:51 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Search for this guy Teknics hes a Mazda Certified Tech, im sure he can help you, and pictures would help also
Old Mar 21, 2009 | 03:01 AM
cfm251's Avatar
yeah ill snap some pics 2morow, i just hope I dont spontaneously combust lol I shall sleep now.
Old Mar 21, 2009 | 05:50 AM
Sounds like the plug/wire for your fuel level sensor...does your gas gauge work?
If so you should be able to use a crimp splice and not worry about it
Old Mar 21, 2009 | 06:51 AM
Jon316G's Avatar
Grasshopper
I can understand your concern... having the possibility of exposed wire in a gas tank seems like a bad idea.
But there isn't enough air in the gas tank to sustain combustion (think of the Fire Tetrahedron).
BUT.. I too would still be nervous if I were in the same situation.
That being said, you can always play it super safe and do this:
Buy butt-splice connectors that shrink wrap at the ends, wrap with electrical tape, then wrap twice with regular shrink wrap.
This should definitely prevent anything from getting through.
Old Mar 23, 2009 | 02:50 AM
cfm251's Avatar
this sounds like a good idea, also makes sense when eerythink is put bac together its pretty much sealed from outside air. Thanks for the imput only worry here is shrink swap involves heat right?
Old Mar 23, 2009 | 02:51 AM
cfm251's Avatar
I dont know, battery is currently in storage being kept charged...
Old Mar 23, 2009 | 09:09 AM
Jon316G's Avatar
Grasshopper
Yeah... is it long enough to get the whole thing out of the tank so you can put a plate over the opening?
it doesn't require a lot of heat so it'll be quick.
Old Mar 23, 2009 | 12:45 PM
teknics's Avatar
Certified Mazda Tech
So it's the wire actually in the tank? You'd probably be fine with a butt connector crimped on but i would definitely rec. trying to get shrinkwrap tube around it for safety's sake.
I cant picture the harness in the fuel tank but i think it's like a short harness with plugs on both sides, you should be able to get it cheaply and replace the whole harness if you want to do it correctly. I could be wrong about it being a short jumper kind of harness but most cars have that type of fuel pump harness.
kevin.
Old Mar 23, 2009 | 01:38 PM
cfm251's Avatar
kevin.
I dont know exactly but when I took out the old pump had to let it drain from the good amount of gas. Harness perhaps is not deep being in the middle of the fuel pump assembly, but at least a certain portion of the wire is in fuel, this is with less than 1/4 of a tank of fuel.
RevMeHarder
Jun 1, 2026 02:30 PM
DVerdeyen
Sep 29, 2015 10:31 PM
DVerdeyen
Sep 13, 2015 11:19 AM
mattymack
Sep 6, 2015 10:33 PM
