Front Main Seal, OC2, and coils
Old Mar 12, 2009 | 10:48 PM
laserjock's Avatar
'04 RX8 GT
I took my 8 into the shop three days ago because the CEL came on, and I was experiencing an oil leak.
After a day of diagnostics they told me the front main seal has gone out, the O2 sensor died, and the coils all need to be replaced.
I was told that if I am experiencing power loss that they will replace the motor if the pressure level was low. Does anyone know what the normal combustion pressure is? Just for the sake of argument when I go back to the dealer.
Also, with the new replacements is it known that they have improved the seals? Heat distribution, etc. I have 25K left on my warranty and was thinking of selling before I hit that point.
Old Mar 13, 2009 | 10:50 AM
VOODOO8's Avatar
Hermitage Holdout
Originally Posted by laserjock
'04 RX8 GT
You'll find a post from MadDog in the link below (first page of the thread) with the standard factory graph for compression over cranking RPMs. Same graph is in many other threads on the site as well:
https://www.rx8club.com/series-i-trouble-shooting-95/blown-motor-77861/
Old Mar 13, 2009 | 10:56 AM
um-- they are going to replace the motor anyway for the front main seal
Old Mar 13, 2009 | 11:08 AM
Come on Charlie Your kidding right
Old Mar 14, 2009 | 03:06 PM
they are going to actually let a "mechanic" replace the seal?
Old Mar 14, 2009 | 04:18 PM
I think they will replace the seal..it's not rocket science...
They replaced mine.......and even did it right the first time
Old Mar 15, 2009 | 12:35 AM
laserjock's Avatar
They are going to replace the seal, had to have warranty adjuster look at it before they approved it... $2200 for all the work!
I don't quite know why they aren't checking compression prior to replacing the seal.... But I guess the dealership needs the money.
I am going to request a compression test on monday before they go any further. It seems like a more common problem than it should be.
Thank you for the posts!
Old Mar 16, 2009 | 11:59 PM
teknics's Avatar
Certified Mazda Tech
front main seal is easy, nice labor time for it too.
kevin.
WingleBeast
22
May 23, 2016 09:22 PM
uZu
Dec 30, 2015 12:35 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
akagc
Aug 11, 2015 07:07 PM
dbarber
Jul 25, 2015 01:34 PM
