System Upgrade
Old Mar 10, 2009 | 06:09 PM
Fate710's Avatar
Super Low & Super Slow
System Upgrade
Been thinkin bout upgrading the stock BOSE system and wanted to run a few things by ya'll.
For the center dash I was thinking of running these:
http://www.parts-express.com/pe/show...number=264-812
Should be a shallow enough depth and produce a good enough sound.
Doors would receive:
http://www.parts-express.com/pe/show...TOKEN=64765147
Seems like a shallow enough depth, can be wired in a few different combos, and would pretty much provide a good midbass, like the original BOSE mid was supposed to do.
OR the doors would receive a set of Morel Elate SW 9" Woofers again used a mids
Now for tweeters:
https://www.rx8club.com/newthread.php?do=newthread&f=24
Then I'd probably find a set of crossovers from Image Dynamics
Rear 6x9s would be replaced with either a set from Morel, Focal, or Rainbow.
Amp duties would be handled by ARC, Image Dynamics or Focal.
I'm not looking for alot of bass because my little girl will be riding in the back. I just am looking for a cleaner overall sound.
Should I even bother to go into this much work or just leave the system as is?
Old Mar 10, 2009 | 07:26 PM
firebirdude's Avatar
User and Abuser
You're happy with the lowend output. Ok.
If you think it sounds a little muddy, swap out the tweeters only. See where that takes you.
Hunterkelley24
Jun 14, 2022 08:32 AM
Quiggs321
Sep 30, 2015 05:34 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
drlubell
Sep 26, 2015 11:58 PM
