Squeaky Alternator Pulley
Old Mar 8, 2009 | 09:52 PM
RX8SaxMan's Avatar
Hey Guys,
My car has been making an annoying chirp/squeak at idle, and I deduced that it's coming from the alternator pulley. If I spray a little WD-40 right in the middle of the bearing the sound goes away, but comes back after a few minutes. Is there a better lube I can put on there to silence it, or do you think my bearing is going bad and should just replace it?
Old Mar 9, 2009 | 10:11 AM
EDZRIDE's Avatar
2005 White GT
Sounds like replacement time.
Old Mar 9, 2009 | 10:33 AM
Atilla's Avatar
I am THAT guy
i'm having the same issue...
Old Mar 9, 2009 | 02:09 PM
RX8SaxMan's Avatar
I suppose I'll look into replacing it. I'm not sure where I would get that part though...
In the meantime I tried rubbing a little white lithium grease in the center bearing of the pulley and that seems to be doing well. It's been a day now and the noise is still gone. I'll be keeping an eye on it to see how long that lasts.
Old Mar 9, 2009 | 02:19 PM
EDZRIDE's Avatar
2005 White GT
Once you get the alternator apart, any bearing supply company should be able to help you. here's a start: https://www.motionindustries.com/mot...p/mi/index.jsp
Old Mar 9, 2009 | 03:25 PM
Icemark's Avatar
double check belt tension too.. if the belt is too tight, it will wear out the bearing much faster than normal
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RXFEVER
Sep 11, 2016 02:51 PM
