trany problem
Old Feb 28, 2009 | 12:05 PM
Currin's Avatar
CopB8
Unhappy trany problem
I searched around but could not find the answer i was looking for.
First, my second gear is making noise when i downshift into it when doing around 40-50. i am guessing thats my syncros in 2nd.
second, now i find that more offten i am in neutral and i try to push the shifter to the left(not into a gear but just in between 1st and 2nd) but it wont let me move the shifter left(no matter how hard i try).
any thoughts on the problems, and how much it would be to fix them.
i just lost my warrenty on my tranny last month.
04 mt with 35,000 miles.
thanks.
Old Feb 28, 2009 | 01:02 PM
AAChaoshand's Avatar
Rotary Powered
what noise is it making? Grinding, poping, etc? As far as the shift goes, I haven't the slightest.
Old Feb 28, 2009 | 01:10 PM
Currin's Avatar
CopB8
its a grinding that goes away after i go in to the gear completely, but it only does it when i am going at a high speed for the gear, like shifting from 3-4 it is fine
Old Feb 28, 2009 | 01:22 PM
I8U's Avatar
I8U
2nd gear grinding was a known problem. Too bad you're out of warranty, hopefully you have a friend that knows how to rebuild transmissions. It ain't cheap.
Old Feb 28, 2009 | 01:37 PM
Ryoma-kun's Avatar
You could do a try and make Mazda replace it. Even if you're out of warranty, they should be kind enough to replace it if it's a common problem.
Old Feb 28, 2009 | 01:40 PM
I8U's Avatar
I8U
He's out of warranty, Mazda won't budge on that...believe me I know.
Old Feb 28, 2009 | 01:44 PM
Shamusodoofus's Avatar
Chances are the dealership won't do a thing if he's out of warranty since they are dealerships and their main goal is profit. Doing it for free without them having any reason to defeats the purpose of that. However, it really depends on the dealership. If he has a good relationship with his dealership and knows the mechanics there's a chance they may do it for free or at a discounted price. But I wouldn't count on that... Hope you get it fixed
Old Feb 28, 2009 | 02:08 PM
VS8's Avatar
VS8
4 Cylinder Rotary
your car tranny is not out of warranty the 04 rx8s have extended powertrain warranty to 60k and engine to 100k
VS8's Avatar
VS8
4 Cylinder Rotary
how did u lose your tranny warranty...did u do something
Old Feb 28, 2009 | 02:25 PM
I8U's Avatar
I8U
^The warranty is 5yr/60k. He is out of warranty.
Old Feb 28, 2009 | 02:50 PM
Ryoma-kun's Avatar
Well that means he's in the 5th year now? That means he's still under warranty or?
Old Feb 28, 2009 | 03:03 PM
That depends when he bought the car. But regardless of that, the OP said his warranty already ran out so I assume he's not covered anymore. I could be wrong though.
Old Feb 28, 2009 | 06:53 PM
Currin's Avatar
CopB8
car was bought the 23 dec of 2003 and it went out in jan of 09. but i might try and see if they will do it for free sence is only a month late, they almost gave my a new amp one time but i was 3 months out of warrenty and they said they might if it was only a month or to.
do you know how much it would cost to fix the frist porblem?
thanks for the help.
theblinkof
Oct 4, 2023 05:24 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
