RX8 rattling sound coming from underneath me
Old Jan 19, 2009 | 11:46 AM
hackdss's Avatar
Hi everyone I got a 2005 mazda rx8 auto transmission and I hear a loud rattling sound when Im in D and Im at a stop light with my foot on the brake but once I start driving sound goes away until I stop again.
The rattling sound is coming from underneath me.
Any Ideas
Old Jan 19, 2009 | 03:39 PM
04RX8man's Avatar
Rotary Powered Countryboy
do you have an aftermarket exhaust? I had the same prob when i got my exhaust was just a hangar rubbing on the rear diff.! Do you have any mods at all done?
Old Jan 19, 2009 | 03:52 PM
nuke0907's Avatar
Never Blend In
broken motor mounts. causing your exhaust to rattle hitting stuff under your car. my exhaust hits the gas tank heat shield.
Old Jan 19, 2009 | 03:57 PM
nuke0907's Avatar
Never Blend In
here's the TSB for it.
Old Jan 19, 2009 | 04:03 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Could just be a something as simple as a loose heat shield rattling.
Perhaps this is a noob question, but is there an easy inspection of the motor mounts? I have an 04 MT, and it vibrates like hell at 750-800 rpm, but then its smooth like butter at 1k rpm.
I haven't ridden in enough 8s to know if that is normal or not.
Old Jan 19, 2009 | 04:22 PM
Jon316G's Avatar
Grasshopper
I too am a little curious. Can you see/feel for cracks around the motor mount? I've never seen a bad motor mount up close.
If I recall correctly, the newer motor mounts have a heat shield due to the exhaust temps.
You could at least check to see if it was ever replaced.
Old Jan 20, 2009 | 07:54 PM
hackdss's Avatar
Tsb
Thanks for the reply
No I do not have any aftermarket parts installed on my rx8 but my vin number is lower that one stated on the TSB if it is a cracked engine mount would mazda cover the repair?
Old Jan 20, 2009 | 08:05 PM
Chris's Avatar
Turbo Member
you might want to check your plugs and coils... mine does the same... check into BHR an awesome solution
Old Jan 20, 2009 | 08:19 PM
Vyndictive's Avatar
If you're out of warranty, which being an '04 you most likely are... no, the repair bill would be on you.
TSBs are not really recalls, they're just common problems released to the dealers so they know how to fix it quickly. Most TSBs were released when the cars still had their bumper to bumper.
Suckers like you and me are S.O.L. when it comes to the TSBs, all we can do is read the TSB and fix it ourselves. Or give the TSB to a shop you trust.
Could still be a lot of different things under there rattling.
Old Jan 20, 2009 | 08:26 PM
hackdss's Avatar
Its an 05 I also notice my steering wheel shake and rattle
Old Jan 20, 2009 | 08:42 PM
Vyndictive's Avatar
Oh, Sorry, I thought it was an '04. My bad... you might have some bumper to bumper warranty left over then. You need to find the original purchase date and I think it has a 4 year bumper to bumper... someone else on here would know that for sure.
Old Jan 20, 2009 | 08:56 PM
hackdss's Avatar
Im going to bring my car to mazda on friday after work and see what they say.
Old Jan 22, 2009 | 08:14 AM
mazdaverx7's Avatar
RX-Heaven
let us know what they say. i would guess that bad motor mount(s) are causing the exhaust rattle..which may be something as simple as a converter heat shield.
Old Jan 22, 2009 | 01:37 PM
toddiesel's Avatar
I have a similar rattle. It mainly does it at idle. I've heard the noise before in a 240sx I had. It was the heat shield. Let us know what you find out though.
Old Jan 24, 2009 | 02:36 PM
hackdss's Avatar
Went to Mazda dealer today found out my warranty has expired in march 08 but anyways the rattling sound has been fixed it was a bent exhaust hanger causing it.
They straightened out the hanger and the vibration is gone thank goodness.
The good news is they didn't charge me. They mentioned that the engine has a misfire but said not to worry about?
Old Apr 29, 2016 | 08:37 AM
ZMIKE's Avatar
To start I love this site it's helped me so many times but beyond that I made an account to help you out here because I had that problem for a year and even sent it in to mechanics while I was deployed and they couldn't fix my misfire but it's unrealistically simple replace your spark plugs, coils, and wiring I used all ngk parts with iridium plugs and it immediately went away I haven't seen it in over 6 months just in that fix alone I noticed a massive improvement in the performance of my RX-8
ei8ht
Aug 21, 2017 09:08 AM
Dokuji
Nov 1, 2016 02:51 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
ironj221
Jul 16, 2015 10:16 PM
