DIY: IAT sensor for turbo
Old Jan 17, 2009 | 05:19 PM
Brettus's Avatar
Boosted Kiwi
I did this modification after pestering Mazda Maniac for details on what he did . So props to MM for coming up with this setup . Hopefully he will jump in and clarify anything that may be a little sketchy.
OK
* First get hold of your sensor from a wrecker. The sensor comes from the KL series motors
Quoting MM here "Its a family of V6 motors that Mazda put in several cars in the 90's.In its 2.5 liter form, it was in the MX-6, 626, 929, Millennia and the Ford Probe.
It was also available as a 1.8 liter (the world's smallest production V6) in the MX-3."
*Make sure you get hold of the plug that plugs into this along with about 400mm of wire attached.
*Now you have to cut the sensor out of the housing along the red line shown .I actually went out a bit farther than the line to make more of a flange. Take care not to cut the end of the temp sensor off when you do this (I almost did) A hacksaw is the best tool to do this with.
This is what it looks like to start with :
Attached Thumbnails DIY: IAT sensor for turbo-vaf.jpg
Old Jan 17, 2009 | 05:21 PM
Brettus's Avatar
Boosted Kiwi
*Now initially you will get something shaped like this :
Please resist the temptation to use this for other activities
*You need to cut around the sensor till you end up with a flange around it like this :
Attached Thumbnails DIY: IAT sensor for turbo-sensor%5B1%5D.jpg
Brettus's Avatar
Boosted Kiwi
*remove all the insulation tape from the maf wires right back to the loom .
*Cut the red wire about 1/2 way along and join it to the wire at the front of the temp. sensor
*Splice into the other wires in the same position as shown below .... use a soldering iron to ensure a good join.
*once you know it all works , wrap insulation tape around both lots of wires
Old Jan 17, 2009 | 05:45 PM
Brettus's Avatar
Boosted Kiwi
*Remove the intake pipe before the throttle body.
*now you need to cut a hole in your intake pipe the same shape as what is under the flange . I put mine very close to the coupling and used the coupling to hold the flange down at one end .
*at the other end i used a self tapping screw to secure the flage to the pipe . A bit mickey mouse I know - there will be a better way .....
*Put some gasket goo of some sort under the flange and mount it on the intake.
Attached Thumbnails DIY: IAT sensor for turbo-temp-sens-1.jpg   DIY: IAT sensor for turbo-temp-sens.jpg
Old Jan 17, 2009 | 10:40 PM
Brettus's Avatar
Boosted Kiwi
* now go out and datalog to your hearts content
Old Jan 18, 2009 | 10:04 AM
09Factor's Avatar
Original Turbo 'd Auto !!
Thats pretty damn slick. i asked MM about this also but he's a busy guy.
Thanks Brett
Old Jan 19, 2009 | 03:23 AM
auzoom's Avatar
Hmmmmmm.........
Nice work Brettus. Just out of interest, what sort of temps are you seeing at what boost?
Cheers
Andrew
Old Jan 19, 2009 | 11:58 AM
Brettus's Avatar
Boosted Kiwi
At cruise I see temps 10-12 degrees above ambient . When I go into boost it stays fairly steady going up a coulpe of degrees under prolonged boost @9-10psi .
What really does raise temps is sitting around at idle or heat soak after you turn off for a few mins . Have seen 25deg C above ambient in those conditions. Any kind of hard driving at low speed is bad as well .
before I relocated the sensor I was seeing way lower temps - stands to reason .
Old Aug 18, 2010 | 06:43 AM
SC-ed's Avatar
Why do we need to splice to the 2nd ground 5U-B?
Old Aug 19, 2010 | 12:23 AM
Brettus's Avatar
Boosted Kiwi
cuz it works ?
Old Aug 19, 2010 | 12:47 AM
MazdaManiac's Avatar
Originally Posted by Brettus
cuz it works ?
Best. Answer. Ever.
Old Mar 21, 2011 | 09:26 PM
Brettus's Avatar
Boosted Kiwi
Just posting this here because it does seem to indicate that doing this mod is worthwhile ....
Attached Thumbnails DIY: IAT sensor for turbo-calc.jpg
Old Mar 21, 2011 | 11:54 PM
Here is the calibration chart for the fast-acting GM IAT:
Attached Thumbnails DIY: IAT sensor for turbo-gm_ias.png
Old Mar 22, 2011 | 01:44 AM
Brettus's Avatar
Boosted Kiwi
So that would be far superior to the Ford one .... right ?
Have you tried this GM one ?
Old Mar 22, 2011 | 02:28 AM
NgoRX8's Avatar
im interested in doing this modification. would be much easier with that GM IAT sensor.
Old Mar 22, 2011 | 10:38 AM
The GM IAT is what I am using now.
It is mounted in the exit-side end tank of my intercooler.
Old Mar 22, 2011 | 11:01 AM
NgoRX8's Avatar
Good to know. Since it is a 2 wire connection is it simply tapping into the MAF sensor wiring for the IAT ground (Black/Green) and cutting/joining the IAT sensor wire (Red/Black) to the new sensor? Not to mention having to rescale the IAT calibration in the tune.
Old Mar 22, 2011 | 11:39 AM
You have to "Y" the two grounds to the sensor and then wire the "hot" side.
It is like the diagram that Brettus posted.
I'll get an actual wiring diagram up here soon.
Old Mar 22, 2011 | 12:06 PM
Brettus's Avatar
Boosted Kiwi
A new DIY using this AEM sensor might be in order ...
The only issue being the inability of most people to change the IAT calibration chart .
Old Mar 22, 2011 | 12:13 PM
laythor's Avatar
I zoom therefore I am.
that's what's Jeef is for. does that make it 12 deadly questions? and can this IAT mask a cell?
Old Mar 22, 2011 | 12:34 PM
NgoRX8's Avatar
lol. still 11 Deadly Questions since it can go in the #10 'Other Relevant Mods' Section.
Considering how many people actually do this mod using this Ford one, I see more people doing this IAT mod given the ease of picking up the GM sensor. Those that would even consider this mod would already have access to IAT calibration adjustments.
Old May 25, 2011 | 04:26 PM
FazdaRX_8's Avatar
What is the fast acting GM IAT part number?
Could you post a picture mm?
Thanks!!
Old May 25, 2011 | 04:48 PM
The MSD part #2320 is the GM PN 12102620. This is the sensor I use in my own car.
Old Jul 5, 2012 | 02:15 PM
Bump. So did anyone aside from MM ever use the GM sensor?
Old Jan 15, 2013 | 09:53 PM
Harlan's Avatar
I know the thread is old, but I'll share what I know for future searchers. The GM curve (look at the resistance table at the bottom) https://www.rx8club.com/attachments/...rbo-gm_ias-png
doesn't even come close to the stock IAT curve under controls-IAT inspection:
M A Z D A
I've got, but haven't installed a golf IAT sensor. I think the curve for it at the bottom of this thread. I had a better one bookmarked but I think I've reinstalled since then:
ABF CLT / IAT sensor pin ID and resistance
It's pretty similar to stock, but it indicates hotter earlier and diverges more at the high end. I played with it for a while comparing it directly to stock at different temperatures it's pretty darn close through most of the range. Also it indicates almost instantly, much faster than stock. I'll post back when I have it installed.
