HELP! DSC and Traction Ctrl. Lights On! Again!
Old Jan 15, 2009 | 05:32 PM
d_mashuda's Avatar
Hey I was wondering if anyone else had this problem. I Had the same problem last year. Ok...Well first off last summer i put subs in the car and hit the wire harness somehow with the drill bit going through the firewall by the steering column. Thats the first mistake...Ik. Ok so i pulled out half of the harness and repaired the 6? wires with factory heatshrink crimp splices, worked and looked like new. After i did that, traction controle light, dsc light were on constant and cruise controle didnt work. Couldn't figure it out so took it to the local mazda dealer and they traced it to the wheel speed controler mounted where all the brake lines all come to a block on the firewall in the engine bay, driver side. So replaced that and fixed everything. Now have the car parked in a non-heated garage for winter (Wisconsin). Went to start it the first time, just to check it and just to run it for a while. First thing, dead battery, so charged it up and fired it up no problem, except the traction controle light was on and the dsc light was flashing, My question is why? Didnt do anything to it, other than the dead battery for maby a month, that should affect that. So i let it run and now have a battery maintainer on the battery to keep it up while not useing it. Lights still on a week later after i let it sit with the maintainer on. So any ideas guys? I tried to cover everything i did here so hopefuly someone can help. Thanks!
Old Jan 15, 2009 | 05:35 PM
skrubol's Avatar
Maybe try turning the steering wheel from lock to lock while it's running? Might be that the stability and traction control lost their programming and need to relearn.
expo1's Avatar
He's as bad as Can
Look up DSC in your owners manual and you will find your answer as to why this happened and how to fix it. You can also search this site. If you don't have a manual you can get one from www.mazdausa.com
Old Jan 15, 2009 | 05:38 PM
StealthTL's Avatar
Hey Expo!
Where ya bin??
S
Old Jan 15, 2009 | 06:28 PM
04RX8man's Avatar
Rotary Powered Countryboy
search the boards and u will find the answer....hint hint needs needs reset from having power (dead battery) disconnected
Old Jan 15, 2009 | 06:31 PM
Easy_E1's Avatar
AZ
Old Jan 15, 2009 | 06:41 PM
expo1's Avatar
He's as bad as Can
Originally Posted by StealthTL
Hey Expo!
Where ya bin??
S
I am still around, wish I was someplace warm.
Old Jan 16, 2009 | 03:20 AM
Hey Expo!
Where ya bin??
S
wow,
he is around more than you..
i kid.. i kid..
expo. cool to see you.
Old Jan 16, 2009 | 06:13 PM
d_mashuda's Avatar
Hey thanks for the help and hints guies, i got lookin around and figured that was the deal, just wanted to be sure and put my mind at ease. I will give it a try and make sure thats the prob!
OfficerFarva
Dec 5, 2015 10:53 AM
Evan Gray
Sep 26, 2015 12:30 PM
