JDM Mirror lights?
Old Dec 12, 2003 | 10:32 AM
Omicron's Avatar
JDM Mirror lights?
Maurice, can you get the JDM "Mirror lights" that mount where the plug is on the underside of the mirrors? If so, how much?
Thanks...
Old Dec 12, 2003 | 02:20 PM
HottRodder's Avatar
O- I recall someone investigating this earlier and discovered that there was no pre-wired harness to back up this mod. Not that it couldn't be added but the assumption was that he could just replace the plug with the light and hook it up. This was not the case.
Old Dec 12, 2003 | 08:54 PM
Jag's Avatar
Jag
Institution Escapee
I'd be interested in these too, I don't imagine it would be too difficult to wire these up yourself even if the harness isn't in place for them.
Old Dec 12, 2003 | 09:11 PM
Omicron's Avatar
Nah, I can create the harness, just not the lights as easily. Hence the question.
Old Dec 22, 2003 | 08:52 PM
Zoom2X's Avatar
Zoomer
Any word on these? I would like to get a pair also.
Old Dec 23, 2003 | 07:53 PM
habinero's Avatar
Omicron,
When would these lights come on? With the interior lights? The headlights maybe? I am also very interested in putting these in if it isn't too hard. I think they look cool. How are you going to create a harness? Will it require splicing into alot of other cables? Thanks
Old Dec 24, 2003 | 12:03 AM
Omicron's Avatar
Lights come on with the interior lights. I figure it'll be pretty easy to tap the mirror light into the existing door light using just 2 wires. Hardest thing will be pulling off the door panel to get to the wires, and that isn't too difficult.
Old Dec 26, 2003 | 03:44 PM
Omicron's Avatar
** BUMP **
Maurice?
Old Dec 26, 2003 | 04:10 PM
Gyro's Avatar
Rotary Abuser
I agree these light would look nice. I was dissapointed when I discovered US spec cars didnt have them (most pre-order users thought we were getting them).
Some info that maybe useful in THIS thread.
Old Dec 26, 2003 | 10:54 PM
RX-8 friend's Avatar
To be legal, these lights should be wired to the turn signals. The common term for them is turn signal repeaters. If you wire them to be on when just driving you may get pulled over in some states. Check out equivilents on GM SUVs.
Old Dec 26, 2003 | 11:09 PM
Omicron's Avatar
No sir, you're thinking of something different. These are lights that are on the bottom of the side mirrors, and are designed to light up the ground, not indicate turns. Take a look at the bottom of your mirrors and you'll see the plastic hole-filling plugs where the lights would go. Thanks for the input though.
Old Jan 5, 2004 | 07:06 PM
Omicron's Avatar
* BUMP *
Old Jan 14, 2004 | 12:30 PM
Maurice tells me these are only available c/w mirror (not parts only). We are looking into building LED ones you can install.
Old Jan 14, 2004 | 09:41 PM
Omicron's Avatar
Nah, don't worry about it. I can build them, if that's the case. Thanks though!
Old Jan 19, 2004 | 01:10 AM
JaySpec7's Avatar
Take a look at the new 5 series bmw... the LEDs are very nice!!! Something similar would be great!!!
vapor2
May 4, 2020 03:53 AM
vapor2
Jul 9, 2016 07:35 AM
extreme_rotary
Sep 30, 2015 09:53 AM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
Tsurugi
Sep 7, 2015 08:27 PM
