Differential gear ratio?
Old Jan 14, 2009 | 09:46 PM
subatomicparticle's Avatar
Can I get a Baum!!
Does any one know the differential gear ratio? I am having trouble finding it.
Old Jan 14, 2009 | 09:47 PM
Year?
Old Jan 14, 2009 | 09:53 PM
staticlag's Avatar
The Professor
4.44 most likely
Old Jan 15, 2009 | 10:42 AM
Can I get a Baum!!
it is an 04. but I am looking for the differential not the trans final drive ratio.
Old Jan 15, 2009 | 11:01 AM
StealthTL's Avatar
Why don't you like 4.44?
Now you've upset Staticlag.
Final drive ratio (gears plus diff) is 1:1 in 5th and .84:1 in sixth......
S
Old Jan 15, 2009 | 12:21 PM
Can I get a Baum!!
right but I am looking for the differential on the drive axle.(the limited slip differential)
Old Jan 15, 2009 | 12:23 PM
dillsrotary's Avatar
jersey fresh
Static was correct earlier, its 4.44.
Old Jan 15, 2009 | 12:45 PM
Can I get a Baum!!
Thanks that just seems awful high to me most cars are like 3.4-3.7:1
Old Jan 15, 2009 | 12:54 PM
Transam kid 01's Avatar
The anti-ricer
Most cars also run on piston engines...
Old Jan 15, 2009 | 02:07 PM
Icemark's Avatar
So you want to do a slower start? The 09 RX-8 has a 4.777.
Old Jan 15, 2009 | 04:04 PM
04RX8man's Avatar
Rotary Powered Countryboy
4.44......in the 04-08....4.777 in 09's trans is 1:1 in 5th(direct drive) 6th...less than 1:1 (overdrive)
Old Jan 15, 2009 | 08:28 PM
StealthTL's Avatar
You're sure it's not, like 3.4???
S
Old Jan 15, 2009 | 09:42 PM
Can I get a Baum!!
no I was just looking for the exact stock number so I can go to a larger gear for more torque.
Old Jan 15, 2009 | 09:49 PM
StealthTL's Avatar
Mazmart on this forum sells 4.777's.....
S
Old Jan 15, 2009 | 10:55 PM
rotarygod's Avatar
I'll never understand why people always want more gearing when it already has too much. And then they came out with the '09s and made it even worse.
Old Jan 15, 2009 | 11:03 PM
Can I get a Baum!!
yeah you're right it already has way too much torque......
Old Jan 16, 2009 | 12:11 AM
05rex8's Avatar
sold the 8... :(
uh oh, someone isn't happy with their 8...
Old Jan 16, 2009 | 03:07 AM
well,
since you have it all figured out.. let us know what is prudent..
Old Jan 16, 2009 | 09:03 AM
staticlag's Avatar
The Professor
I like my 4.77 gears better than all the other bolt on mods I have had (except wheels), and I have had them all.
Only thing that bothers me is the mileage and the ratio of 6th with the swap. 80mph on the interstate is pretty close to 5K rpms.
Old Jan 16, 2009 | 09:19 AM
rotarygod's Avatar
Gearing has absolutely nothing to do with how much torque your engine makes. Only displacement and VE do. Torque doesn't move you anyways. It moves nothing. Horsepower does.
Old Jan 16, 2009 | 09:21 AM
The anti-ricer
What is this torque you speak of ???
Old Jan 16, 2009 | 09:39 AM
Can I get a Baum!!
Don't get me wrong I love my whip I have had it for 4 years now but just like everyone else on this site I am trying to get more power out of it and it needs help in the bottom end. And gearing has everything to do with torque. That is the purpose of a transmission the whole smaller gear driving a larger gear multiplies the torque of the engine. Even in large displacement V8's they don't produce enough torque to move the car well enough on there own. And torque is exactly what gets you moving horsepower just keeps it going and produces the top end which the car has
Old Jan 16, 2009 | 11:01 AM
rotarygod's Avatar
Silly me. I've already written about horsepower and torque elsewhere. This thread is a good place to start. It talks about the effects of horsepower and torque on engine design. However on page 2 it deals with the whole "torque moves you" thing. The second link is that post.
https://www.rx8club.com/showthread.p...ght=horsepower
https://www.rx8club.com/showpost.php...6&postcount=26
Old Jan 16, 2009 | 12:12 PM
Can I get a Baum!!
You have some good info in there but to put your theory to the test try putting your 8 in 5th gear(direct drivewhich is 4th gear in most cars) or a 1:1 torque multiplication from a dead stop and see where you go. It is true that hp is what will keep you going but without torque you are not getting anywhere quickly. Your horsepower is constant through you gears not your torque. And yes engines are built bigger to handle torque not hp do to longevity of the engine but when building a track car I am not concerned with engine life and driveability I am concerned with winning.
Old Jan 16, 2009 | 12:15 PM
tubingchamp's Avatar
What mawd bug?
Man... Are you trying to argue with RG?.... Kind of pointless, just read his threads and learn.
