Anyone with the Greddy oil relocation have input?
Old Jan 11, 2009 | 03:54 PM
RX8YA's Avatar
WAH WAH WAH
I have read there are two different kits and depending on which you receive you might have difficulties? I would like to know if there is any downside to installing this product and although its really just a product that just makes a task like oil changes easier how is your overall experience with the product.
Old Jan 11, 2009 | 04:03 PM
nuke0907's Avatar
Never Blend In
it makes for easier oil changes and less messy. it also has ports on it for connecting gauges or something like that.
Old Jan 11, 2009 | 04:28 PM
I have one I made myself....used a lot of Earl's billet parts...it definitely makes oil changes easier...and you can use different/larger oil filters as well
Old Jan 12, 2009 | 05:29 PM
04RX8man's Avatar
Rotary Powered Countryboy
oh there are ports for like oil pressure and things like that right?
Old Jan 12, 2009 | 06:28 PM
Depends on the adapter you use..most have 2...
Old Jan 13, 2009 | 06:36 PM
CraigRX8's Avatar
CraigRX8
did you do a right up for this or a list of parts needed
Old Jan 13, 2009 | 06:55 PM
You need the adapter to the block......2 adapters to -10AN hose, 2 more adapters to -10 hose...and the oil filter adapter on the other end...and twice the length between the 2 adapters in -10 SS braided hose...
U can use basically anything for the oil filter end...as long as you understand what type of filter you will need to use that fits
Old Jan 13, 2009 | 07:24 PM
heyarnold69's Avatar
Rotary wanabee
they are the same as a chevy truck oil filter
Old Jan 14, 2009 | 01:06 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
What is the retail on one of the relocate kits, and anyone have any installed pics? I have thought of trying to make one myself...the position and the angle/design of the stock filter BLOWS GOATS...
the pedestal tilts one way, out of necessity. But mazda put the F'ing oil drain hole on the OTHER side of the pedestal...meaning oil will ALWAYS be retained (and spilled) no matter how long you let it drain before removing the filter.
Old Jan 14, 2009 | 06:28 AM
CraigRX8's Avatar
CraigRX8
what size do you need for the adapter? Not selling a kit yet charles? Can you get me parts
Old Jan 14, 2009 | 09:15 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
I use a regular Mazda OEM type filter with mine. No need for the expensive Greddy filter.
Old Jan 14, 2009 | 09:20 AM
tdiddy's Avatar
Pics of mine installed.
Old Jan 14, 2009 | 09:29 AM
czar's Avatar
Almost boosted
...that looks very convenient, i was thinking of buying one from fluid
it has a tap on the bottom ? is that a 1/8th ?
Old Jan 14, 2009 | 09:38 AM
tdiddy's Avatar
It has like 4 ports and they are either 1/8 NPT or 1/8 BSPT.
Old Jan 14, 2009 | 10:01 AM
rotary.enthusiast's Avatar
The Local Idiot
I bought one of these a while back and never installed it. Without running much longer braided lines than came with it, I couldn't find a decent place to install it other than where you see tdiddy's. I've since bought the RB oil filter adapter that has ports for gauges/sending units, and just deal with banging my knuckles when changing the oil. I've been toying with the idea of throwing the Greddy unit up in the parts for sale forum.
I can confirm that the OE mazda filter does indeed fit on this adapter.
Old Jan 14, 2009 | 10:25 AM
Is it better for the filter to be horizontal or vertical? I would think vertical.
Old Jan 14, 2009 | 10:33 AM
czar's Avatar
Almost boosted
shouldn't matter.
Old Jan 14, 2009 | 01:07 PM
I wonder why mazda did not choose to relocate the oil filter on these cars...like an early 90's chevy blazer.
I would think that it would not be worthwhile to mount it right on the firewall...you are still suceptible to spillage. I would use longer lines and run it down to a frame rail somewhere so that it is easily accessible from under the car, like a v8 engine. Then when you loosen it, the pan goes directly underneath and catches any spillage with no need for towels to catch it.
Old Jan 15, 2009 | 02:44 PM
Nubo's Avatar
Lubricious
To each his own. They look nice and add some convenience, but I find the stock filter really isn't that difficult to deal with. A couple of shop rags around the base, the right socket extensions and filter cap and it's done fairly easily. Not sure the small added convenience is worth an additional 8 pieces in the critical path but I'm sure it works fine for most, maybe all. On the other hand if you want oil temp and/or real oil pressure info; it would seem to be the way to go.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
RXFEVER
Sep 11, 2016 02:51 PM
DVerdeyen
Sep 13, 2015 11:19 AM
