cap in headlight needs snapped
Old Jan 10, 2009 | 08:25 AM
foxgoku's Avatar
I got into a little fender bender the other day and was looking at my right headlight. I noticed that the little cap for the light on the inside corner of the assembly was not snapped into place but was aligned just off of it. I was wondering if there was a technique to get this to snap into place. It appears that is is completely lined up and just needs to snap in. Sorry if this is on here somewhere however I could not find it when I searched. Thanks for all your help.
Old Jan 10, 2009 | 08:31 AM
04RX8man's Avatar
Rotary Powered Countryboy
probably have to take the headlight off and get inside the cover and "snap" it back in!
Old Jan 10, 2009 | 09:33 AM
foxgoku's Avatar
Is there a way to actually get inside the assembly then? I didn't know if you could or not. I was under the impression that the cover and the rest of the assembly was sealed to each other.
Old Jan 10, 2009 | 09:36 AM
Renesis07's Avatar
Vtak just kicked in yo!!
bake it, open it, pop it back on, put it back together, re assemble.
THere are a few threads about opening up the headlights from people painting them, search around.
I would do it for you but Im multi tasking at work here
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
