Engine won't start, sound like has no compression ! :(
Old Jan 3, 2009 | 05:05 AM
Chris_G9's Avatar
Car : Mazda RX 8 04 6mt
So yesterday morning i moved my car about 10 meters and after 6-7 hours i try to start it but nothing happens ! First is sound like low battery but today i put on a new one ! The engine still not start, now is sound to me that the compression is low...
You do you think i have to check first ? I need help...
Old Jan 3, 2009 | 08:08 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Use this.
http://www.finishlineperformance.com...5-08-1883f.pdf
Some people(with someone else there to assist) just pull the fuel pump relay and attempt to start the car. Once it fires............plug that relay in really quick and keep it running.
Think if I knew it was flooded, I'd go ahead and pull the plugs first to look, as most times they are soaked and need to be cleaned or replaced. While the plugs are out either follow those instructions above or pull the fuel pump relay and get all that unburnt fuel out of there by cranking the engine. Put a cloth or rag near the plug holes!
Old Jan 3, 2009 | 10:29 AM
mazdaverx7's Avatar
RX-Heaven
pull and gently clean the plugs. remove the fuel pump relay. add a small amount of oil into the lower plug holes(if its really flooded) and reinstall the plugs. crank the engine. when it starts, reinstall the fuel pump relay.
Old Jan 4, 2009 | 04:44 AM
Chris_G9's Avatar
I will try to do this today with a little help....! I hope this is the problem ... Thanks a lot Mazurfer and mazdaverx7 !
Old Jan 4, 2009 | 12:46 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah just sounds flooded follow the above procedure and u should have no problem and have it up and runningwithin a half hour
Old Jan 4, 2009 | 05:48 PM
mazdaverx7's Avatar
RX-Heaven
did you manage to get the engine up and running?
Old Jan 5, 2009 | 03:32 AM
Chris_G9's Avatar
Not yet.... Today my engineer will be connect the Diagnostic to the car to find out what is happening....
Old Jan 5, 2009 | 05:00 AM
mazdaverx7's Avatar
RX-Heaven
is the CEL coming on at all?
Old Jan 5, 2009 | 09:20 AM
Chris_G9's Avatar
Finally i brought my car home... I change my spark plugs only !
Old Jan 5, 2009 | 02:10 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
So, spark plugs caused the car to not start after it started fine and ran for a few moments...
I think it was flooded and the old plugs may have been fine.
Old Jan 6, 2009 | 03:20 AM
Chris_G9's Avatar
My old spark plugs...
Old Jan 6, 2009 | 08:56 AM
Vyndictive's Avatar
^ hmm. . . new ones probably won't hurt anything.
I retract my statement.
Old Jan 6, 2009 | 11:23 AM
They should be a little more tan for the RX8 as they are all some what black because they run rich.
Best thing to do is either buy the coils form BHR (hotter spark) or buy the AP from MM (proper AF ratio).
Either item should prevent flooding from occuring again.
Old Jun 6, 2011 | 02:55 PM
Ianhomer1's Avatar
Hi need sum phone numbers for good rx8 engine rebuilds in north west can anyone help ?
Old Dec 12, 2012 | 11:52 AM
anayamjl's Avatar
i need help
im new to this club. I have a 04 mazda rx8 with 96086 miles and its been at the shop cuz it wont start. they said that i need it a fuel pump, and after they put it on i didnt start. so now they telling me that i need a new engine, that i lost my compresion. can anyone tell me what to do!
Old Dec 12, 2012 | 12:07 PM
EDZRIDE's Avatar
2005 White GT
Have it replaced.
Old Dec 12, 2012 | 12:11 PM
anayamjl's Avatar
is that the last option cuz i cant really afford a new engine
Old Dec 12, 2012 | 01:52 PM
Bladecutter's Avatar
Rockie Mountain Newbie
Pay shop money.
Get new engine.
See if car starts.
Drive away happy.
BC.
Old Dec 12, 2012 | 02:12 PM
Loki's Avatar
Have they measured the compression? What are the numbers?
FYI, the engine is under warranty for 8 years or 100,000 miles (from time of original sale). 8 years is up for most 2004's, but hey, maybe yours was sold just before Christmas.
Old Dec 12, 2012 | 02:41 PM
wcs's Avatar
wcs
no agenda
Originally Posted by Bladecutter
Pay shop money.
Get new engine.
See if car starts.
Drive away happy.
BC.
LOL
Where have I seen this before?
Old Dec 12, 2012 | 04:53 PM
Hector Castillo's Avatar
wont hurt anything at all!!! lol
Old Jan 26, 2013 | 04:56 AM
icymania's Avatar
The dreaded day has come .. engine rebuild..
Hi all
I am very new to this rx8 club , so new infact i dont actually know how to start my own thread!!!
im hoping someone on her can help me to do that aswell... anyway..
the dreaded day has come i have had my rx8 for 5 months and last week the engine wouldnt start..
i took it to a mazda dealership who done two tests,, a diagnostic and the low compression test,, which actually cost me 185:00 sterling english pounds!! as i live in the uk
anyway the results from the test are as follows..
cars is flooded, found leads not sitting tightly also front rotor plug cracked,( this plug is now on rear) this car must have been misfiring and overfuelling,
cat melted internally with bits in the exhaust system, advised new cat and exhaust system , new plugs, ht leads and coils once runnung..
compression test front 3.4, 3.9, 3.8 rear 3.8, 4.2, 4.2
mazda state anything below 5.0 requires a new engine
so all in all i need an engine rebuild, new cat and possibly a new exhaust system
if you have seen my photo album of the car you can understand why it would kill me to scrap this car.. plus i bought it 5 months ago from a car dealership not a mazda dealership for 2650 which i though was a bargain!!
with me having no knowledge of rotary engines and how to maintain them i feel the fault was partly mine and also partly the previous owner (whoever that is)
the question i ask is,, if i get this rebuilt and the knowledge i have now to look after and maintain the car.. could this happen again two years or more down the line..
p.s all my friends are saying dont do it and get a totally different car,, but in the 5 months i have had the car i absolutley adore her,, plus i got her new shoes, tints an added to the bose system with my own bass box in the boot, and i feel i havent had her long enough to disown and hand her to the scrapyard.. any advise would be much appreciated
thanks
Old Jan 26, 2013 | 07:50 AM
wcs's Avatar
wcs
no agenda
Originally Posted by icymania
Hi all
thanks
Wow that's a sad story.
I really feel horrible for that RX8
I'm going to go with ... a rotary is too much for you to handle, sell it in hopes that it goes to a better home.
here's some karma for your car getting purchased by a fellow rotard
Old Jan 14, 2014 | 10:18 PM
Joeito24's Avatar
I hope you guys can answer my question my car overheated i found water everywhere when I opened it up first time it ever happened to me I lost power in the car I got it towed to my house It turned on that night but it does not want to turn on know it sound it like the engine has no compression am not sure what to do or what is wrong with it .
Jaco Greyling
Jan 6, 2019 08:39 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
dbarber
Jul 25, 2015 01:34 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
