4-rotor Renesis(?)
Old Dec 9, 2008 | 11:03 AM
Psychopath's Avatar
4-rotor Renesis(?)
I' d like to ask some (probably stupid) questions
1) The current 4rotor engines are built from rx7 13b and older engine models only?
2) Did anyone made a 4rotor from renesis?
3) If not, is it possible? (exept the regular issues about building a 4rotor)
4) Can wankels burn biofuel? (imagine a 4rotor on biofuel)
(if those have already been discused could you giveme the link?)
THANK YOU
Old Dec 9, 2008 | 11:07 AM
dozer's Avatar
on his 3rd rx8
Lollersauce!
Old Dec 9, 2008 | 11:10 AM
*sigh*
1 post n00b strikes again !!!!!!!!!!!
Run for ur livessssssssssssssssssssssssssssss !
Old Dec 9, 2008 | 11:13 AM
greg985's Avatar
The 337
well he is a Psychopath
Old Dec 9, 2008 | 11:17 AM
Does that mean I can't run away from him ?
Old Dec 9, 2008 | 11:28 AM
Psychopath's Avatar
why is it so bad asking some question?
i am taking my very first steps on rotary which i find intresting
Wankel is a GREAT engine
i am trying to collect informations on the net but it is difficult since my english arent good
(or there is a lack of info)
it is just not nice...
Old Dec 9, 2008 | 11:29 AM
alnielsen's Avatar
Maybe others can't be civil, but I will.
1) The current 4rotor engines are built from rx7 13b and older engine models only? As far as I know
2) Did anyone made a 4rotor from renesis? I haven't heard of any. There is a 3 rotor engine that has been built in the UK.
3) If not, is it possible? (exept the regular issues about building a 4rotor) Possible.. I would think yes, Practical.. probably not.
4) Can wankels burn biofuel? (imagine a 4rotor on biofuel) By biofuel, do you mean a diesel replacement, then no. There isn't enough compression to fire off diesel. If you mean Alcohal or E85, it could be possible with modification.
(if those have already been discused could you giveme the link?) You will need to use the Search function. I don't have the links off the top of my head.
Old Dec 9, 2008 | 11:40 AM
Psychopath's Avatar
THANK YOU!
1.Practical not, because the ports are on the side?
Or about the ECU managment?
Cranksaft?
2.Yeah, Alcohol or e85. Perhaps it will raise the power...
Old Dec 9, 2008 | 11:57 AM
E85 will not raise any power. it actually has less power than the regular gasoline we use.
Someone made a 4- rotor renesis. e-shaft is the problem. and its pretty hard to get the side port timing + cooling right.
Old Dec 9, 2008 | 12:33 PM
Psychopath's Avatar
Thank you nycgps.
I thought that koenigsegg ccxr was more powerful because its using e85
"According to Keonigsegg, the CCXR's performance is even better than that of the standard CCX thanks to the bio-fuel, "the ethanol in bio-fuel has the positive side effect of cooling the combustion chambers, as well as a higher octane value, well over 100 RON, which gives the high power." The company explains that for this reason, the power reaches up to 1018 hp at 7200 rpm, and the torque can reach up to 1060 nm at 6100 rpm."
http://thefutureofthings.com/pod/106...ports-car.html
it might do the same for 13b
Old Dec 9, 2008 | 12:36 PM
mysql's Avatar
Doppelgänger
uh. There's a recent thread from yesterday with a guy who has a 26b in his rx8.
Old Dec 9, 2008 | 12:40 PM
EdwardsB's Avatar
Registered RX-8 User
the e85 allows for higher compression ratios due to the higher octane rating (reduces the chances of det). the higher octane rating itself does not make more power, it need the higher compression ratio.
btw you cannot search the internet because your english is not that good, but you can understand what we are saying?
Old Dec 9, 2008 | 12:41 PM
alnielsen's Avatar
Originally Posted by Psychopath
THANK YOU!
Cranksaft?
I would also think e-shaft flex would be a problem. The true Mazda made 4 rotor engine had a shaft bearing in the middle to eliminate the wobble. The present day 4 rotors, built in Australia I think, are made from pieces of 13B-REW engines.
Like nycgps said, E85 & ethanol have less power per volume than gasoline. To get the same potential you have to increase the amount burned and/or increase the compression. Compression can be increased because the ethanol burns slower.
Old Dec 9, 2008 | 12:45 PM
alnielsen's Avatar
Link?
Old Dec 9, 2008 | 12:51 PM
Psychopath's Avatar
Thank you guys you are the BEST!
Sorry for being so ignorant (am i spelling it right?)
If i have some more questions can i ask or i am bothering you?
Thank you again!
Old Dec 9, 2008 | 12:52 PM
only at the "normal" gasoline engine compression. with alcohol in the mix the compression can be made higher resulting in HP gains and equal or better mpg
read here http://www.epa.gov/otaq/presentation...-isaf-no55.pdf
Old Dec 9, 2008 | 01:09 PM
Psychopath's Avatar
i can not find it
Old Dec 9, 2008 | 01:16 PM
Silver06's Avatar
Zoom Zoom....
alneilsen & Psychopath...
Here is the 26B thread from the RX-7 Club website... http://www.rx7club.com/showthread.php?t=739941
I'm sure it was here also....
Ahhhh... Found it: 4 Rotor Turbo Rx8
Old Dec 9, 2008 | 01:47 PM
dozer's Avatar
on his 3rd rx8
SKIP ALL THE BULLSH*T get down to the point and just put one of these in your car
Old Dec 9, 2008 | 01:51 PM
good luck getting the Tuning done
Old Dec 9, 2008 | 01:54 PM
Silver06's Avatar
Zoom Zoom....
Nycgps.
I'd think that by the time you got to that stage, tuning would be the least of your worries; LOL.
That' there's second Mortgage $$$.
Old Dec 9, 2008 | 01:55 PM
Originally Posted by Silver06
Nycgps.
So does that mean if I can get that to work I will be the next 2 fast 2 furious : king of Interstate 495 ?
Old Dec 9, 2008 | 01:57 PM
Silver06's Avatar
Zoom Zoom....
^ I think I495 would just pass in a blurrrrrrrrrrrrrr......
(as long as your fuel tanker truck could keep up, that is)
Old Dec 9, 2008 | 02:06 PM
yea ... cuz I have a feeling that thing gives me like 2 mpg or something ...
Old Dec 9, 2008 | 02:11 PM
alnielsen's Avatar
I meet that guy at the 24 Hrs of Daytona (07 race) a year ago and had his phone number. He said he was working on getting a ecu working for a Aussie 4 rotor. I didn't know he was going to put it in an 8.
