synchros?
Old Dec 5, 2008 | 06:43 PM
NitrousHappy's Avatar
synchros?
hey guys, i have recently been having problems with 2nd gear grinding during a 5k and higher rpm upshift. I have searched and it didnt take long to see this is a very common problem. I have seen in some threads that people have had the synchros replaced by the dealer. Since i am broke and prefer to do it myself i was wondering if there is anywhere besides the dealer that i can get the synchros. I figure that while im in there i will go ahead and replace all of them because it also grinds a little bit on a downshift from 6-5th. Any help would be appreciated. Thanks in advance.
Chris
Old Dec 5, 2008 | 07:25 PM
04RX8man's Avatar
Rotary Powered Countryboy
i would try changing your fluid first and if you don't know alot about tranny's i woiujld not try it yourself....becuse if you get in there and can't get it back together you will end up paying more to fix something u might have broke.....try a new tranny oil somehting synthetic and see if that takes care of ur prob it doesn't sound like a synchro jjust sort of like needs a new fluid exhange
Old Dec 5, 2008 | 07:36 PM
I have thought about that before. I did put royal purple 75W90 gear oil in my tranny and differential just a year ago. I have only owned it since last june so i dont know how well the previous owner took care of it. It currently has just under 60k on it. I put about 26k on the car in the time i have owned it. I usually drive moderately but sometimes feel froggy and beat the hell out of it. Not sure how much this information will help but i thought i would put it out there. I will go ahead and put some new fluid in it this weekend and see how it does. thanks
Old Dec 5, 2008 | 07:41 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
Many of us, myself included, had grinding after using RP in our trannies. Switch to Redline MT-90 and your grinding will likely go away like mine did in the first 5 minutes after the switch.... been gone since.
Old Dec 5, 2008 | 07:59 PM
looks like i should have read a few more threads before posting. I do have one question about that grind. Did it just grind for a split second or did it seem like the shifter refused to go into 2nd until it revved down to about 2500rpm? I suppose i can give redline a try. thanks for the advice.
chris
Old Dec 5, 2008 | 08:09 PM
HERO's Avatar
switch to redline fluids for the tranny and also change out your brake/clutch fluid if it hasnt been changed before. make sure its bled properly as well.
Old Dec 5, 2008 | 08:16 PM
well, im going to have to deal with it as it is until i get paid next friday. At that time i will change to the redline fluids. I didnt know redline made a brake fluid or am i simply misunderstanding?
chris
Old Dec 5, 2008 | 10:57 PM
ok i feel really bad. I was just at a little get together of car enthusiasts and there was a couple of younger(16-18years of age) guys running their mouth to each other. They finally decided to race each other, yes on the street. No i dont condone this but i was curious who would win so i followed behind. They raced from 30 mph until one of them gave up. When i went to leave and watch the race i couldnt get my car into reverse! It just wouldnt go no matter what i did. After i got it backed out, i followed the two younger guys to where they raced. This is a race between one of those new toyota corolla XLR's and a older mitsubishi eclipse. Both cars had some basic boltons. I was in second gear when they took off. I was surprised and really disappointed when i just stayed with them and couldnt really pull up on them. When we went back to the parking lot the mitsubishi(who lost by the way) started talking **** to me! This obviously pissed me off but just blew him off. He kept running his mouth and finally i just had to shut him up. NO I DIDNT RACE HIM! I scared him. I just told him i needed a minute to run to my place and get my little blue bottle. He decided he didnt want to race after all. Eventfull night. ok, im done venting.
Old Dec 5, 2008 | 11:10 PM
greg985's Avatar
The 337
^well reverse does not have a synchros so it is normally more difficult to get into gear. If you can get it into reverse just pull on the shifter and back out like normal, it will normally fall into place. BTW are you pushing down on the shifter while trying to put it into reverse?
Old Dec 6, 2008 | 12:25 AM
i push the shifter down to get it to go over then just let it go in reverse the same as any other gear
Old Dec 6, 2008 | 08:20 AM
Do immediately:
Change tranny fluid to redline MT-90
Bleed clutch slave cylinder
Drive and enjoy... Oh and no more dopey street racing.
Old Dec 6, 2008 | 11:04 AM
And check your clutch pedal bracket.....it can cause the clutch to engage erratically and that can cause the shifting problem as well
Old Dec 6, 2008 | 03:51 PM
Unfortunately i cant do the fluid change immediately due to money problems. I dont get paid until next friday and money is tight right now with the holiday season. I will order the redline fluids next week.
Max im not the one street racing i just watched. Its not often i do that either.
thanks for the advice guys ill go check the pedal bracket right now and change the fluid when i get the money.
Old Dec 6, 2008 | 05:33 PM
04RX8man's Avatar
Redline fluids for sure!!!
Old Dec 7, 2008 | 05:07 PM
what bracket?
+1 for checking the clutch pedal and x1000 for Redline.
Old Dec 7, 2008 | 05:08 PM
Sorry man...can't catch them all
I liked Jeff's list the other day
A diagnostic routine goes like this:
1) cheap to expensive
2) easy to difficult
3) most likely to least likely
4) electrical to mechanical
Old Dec 7, 2008 | 05:24 PM
Still better than the usual "shotgun" approach that it seems most take
Ever figure out the SPEC thing
theblinkof
Oct 4, 2023 05:24 PM
dancingdan42
Aug 19, 2015 09:29 AM
Shijin-Kun
10
May 1, 2009 07:00 PM
djseto
32
Apr 4, 2006 04:24 PM
