Can u put 16s on an rx8
Old Dec 8, 2003 | 10:52 AM
cptmorgan2000's Avatar
just wondering if you can fit 16" rims on an rx-8. I was talking to someone and he said try to put 16s on there.. 1st of 16" snow tires are cheaper than 17 / 18... if i were to use 16" rims can i use 225/55/16. if not what would be a good size snow tire to use w/ 16" rims...
Old Dec 8, 2003 | 10:54 AM
Omicron's Avatar
Don't think so... the brakes won't fit. I believe 17s are the smallest that will fit.
Old Dec 8, 2003 | 11:14 AM
Gord96BRG's Avatar
If your RX-8 came with 16s, then sure! Base model and all that... If it came with 18s and has the larger front brakes, then so far the answer is no - and believe me, many of us tried quite hard to find 16s that would fit for the cheaper winter tire options! There were rumours that the OEM RX-8 16s would fit over the bigger brakes of the cars equipped with 18" wheels, but I haven't seen anyone here that has tried it - and I couldn't find take-off RX-8 16" wheels in time for winter anyway.
Regards,
Gordon
Old Dec 11, 2003 | 10:02 PM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
Only if your car is a bone stock non optioned automatic transmission (AT) equipped RX-8.
Anything with the sport pkg on up (S, T and GT) and you will not be able to get the wheels to fit over the larger brake calipers that come with the option pkgs.
Panthersn
Jul 13, 2021 06:30 AM
Zank300
Aug 26, 2015 07:40 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
Belalnabi
Jul 17, 2015 07:48 PM
