AMSOIL Fluid Questions
Old Dec 2, 2008 | 05:31 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
First off, sorry to everyone who have had some issues using RP Maxgear in their manual transmissions. I bought some for my transmission and differential and have yet to put them in. Appreciate the updated feedback to avoid using it in the transmission.
My questions:
1. I think I will be using AMSOIL for the transmission, is this what people are using?
Manual Transmission & Transaxle Gear Lube 75W-90 (GL-4)
2. Can I still use the RP MaxGear in the differential? If I go with AMSOIL, it looks like I should use Severe Gear 75W-90?
Old Dec 2, 2008 | 05:49 PM
LionZoo's Avatar
road warrior
1. Is that the GL-4 fluid? If it is, then that should be good to go. If you want an alternative to Amsoil, you can try the Motorcraft XT-M5-QS.
2. You can still use Royal Purple in the diff. The Severe Gear will also work back there.
Old Dec 2, 2008 | 05:53 PM
^ Yes, that is the GL-4 only fluid. I know now to avoid any GL-5 in the transmission fluid. Thanks about the diff.
Old Dec 3, 2008 | 06:04 PM
04RX8man's Avatar
Rotary Powered Countryboy
should work very very well with it that's what i'm thinkin about using in mine
Old Dec 3, 2008 | 09:57 PM
tunerwannab's Avatar
I put that in my transmission monday and so far so good. I will wait until my next "spirited" drive before giving my impressions though.
Old Dec 5, 2008 | 12:30 AM
Look forward to hearing your feedback.
yankeepicker
Sep 11, 2015 05:42 PM
GARCIAC951
Sep 10, 2015 07:17 PM
Juan Montenegro
Sep 10, 2015 06:28 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
