cold night - engine wont turn over
Old Nov 28, 2008 | 09:58 AM
goodjam's Avatar
Cranks, No Start
Hello all
I woke up this mrng after a cold night if u can believe that in Arizona & can won't turn over.
Jumping didnt help..was a little low on gas filled with three gallons let guage move up and still nothing..
Any suggestions would be greatful
email is faster as I may be outside with car
mazda8@p4nl.com
Old Nov 28, 2008 | 10:16 AM
Is it just cranking? You probably flooded it. Does it sound like it wants to start? Did you shut it down cold?
Old Nov 28, 2008 | 10:54 AM
Silver06's Avatar
Zoom Zoom....
No crank and battery is ok & jumped from a running car, right?
- Do you have good power to the car?
(turn on the high beams and see if bright or dim).
- Do you have a click from the starter solenoid?
(listen in the engine compartment)
My bet is a gentle tap(s) on the starter with a wooden hammer handle will free up moisture frozen in the starter solenoid or bendix drive.
sending you email as well...
Old Nov 28, 2008 | 11:27 AM
goodjam's Avatar
Shut down warm
Tried jumping from an SUV
Starter sounds fine it cracks just wont turn over
Neighbor seems to think the injectors aren't getting fuel
Old Nov 28, 2008 | 11:32 AM
Silver06's Avatar
Zoom Zoom....
A little terminology will help you get a better solution...
NO CRANK means that the starter motor is not turning the engine over (turning over means that the rotors are turning).
CRANKS, NO START is the problem that you have clarified that you are having.
From Mazda's TSB to dealers: "A cranks, no start condition may be caused either by fuel flooded spark plugs or lower than normal compression due to apex seals locked into rotor groove from carbon accumulation."
Link to the TSB: http://www.finishlineperformance.com...5-08-1883f.pdf
Old Nov 28, 2008 | 11:36 AM
goodjam's Avatar
Yes I have
Old Nov 28, 2008 | 12:02 PM
Silver06's Avatar
Zoom Zoom....
Change the thread title...
Old Nov 29, 2008 | 07:25 PM
Try the deflooding procedure.
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
F51
Aug 2, 2021 04:07 AM
vapor2
Nov 3, 2020 03:38 PM
dbarber
Jul 25, 2015 01:34 PM
