MS Cold Air Intake
Old Nov 26, 2008 | 07:52 PM
tubingchamp's Avatar
What mawd bug?
MS Cold Air Intake
Hey all,
Having issues with the Mazdaspeed CAI.
I keep getting the misfire CEL (my car CLEARLY bogs under mid throttle over 4k RPM), idle is terrible, but it sounds sexy.
Ive taken the screens out a couple times and tried them in different configurations.
I had the CEL and other info scanned by Dannobre, it said I was at 40% load at idle (not sure if normal or not) and 100% load around 7k rpm, AFRs are high (I burned 1/4 a tank in 61 kilometres)..
I don't have access to the exact numbers, but I'd like to know if anyone has any ideas?
I know Footman tried to help me for a little while, but the screens should be installed all right now that its been done a few times by a couple different people (myself and Dan)
Comments/Ideas?!
Old Nov 26, 2008 | 07:57 PM
Easy_E1's Avatar
Bad plugs, bad coils, bad cat. Is the air filter plugged/dirty?
Old Nov 26, 2008 | 08:11 PM
What mawd bug?
Coils replaced 10K ago, plugs are fine, cat is new, stealership cleaned the filter not long before I took it off the first time.
Old Nov 26, 2008 | 08:33 PM
9G Redline's Avatar
Trolling since 2004
The only time I have that problem is when the filter gets wet (on rainy days) or when the MAF gets dirty (happens periodically). Other than that I've never had such an issue out of my MS CAI. I've had it since 15k and I'm now at 82K.
Old Nov 26, 2008 | 09:01 PM
What mawd bug?
Mm, my filter is DEFS dry, it was sitting in a closed box for a while (no dust)
is 20,000 KMS enough to dirty a MAF?
Old Nov 26, 2008 | 09:07 PM
20K km is WAY MORE THAN ENOUGH to get a dirty MAF.
clean it.
Old Nov 26, 2008 | 09:11 PM
Jon316G's Avatar
Grasshopper
^^+1
Old Nov 26, 2008 | 09:15 PM
Only problem with the dirty MAF theory is it runs perfect with the stock airbox...and as soon as we switch it out it runs like crap.....
Will try the MAF clean..but there is something else rotten in the State of Denmark
Old Nov 26, 2008 | 10:13 PM
What mawd bug?
How'd you know I'm half danish?
Ehh did I tell you once? I think I did...
You have MAF cleaner Dan?
Old Nov 26, 2008 | 10:54 PM
Nope...you can buy a can
Old Nov 26, 2008 | 11:16 PM
What mawd bug?
Where do you get it around here?
Old Nov 26, 2008 | 11:17 PM
Lordco? or AutopartsPlus?Crappy Tire? dunno.....
Old Nov 27, 2008 | 06:12 AM
Jon316G's Avatar
Grasshopper
It working fine with the stock airbox is strange and leads me away from the MAF sensor.
Did you remember to cap the VFAD nipple on the intake manifold?
And I read over your first post again and you mentioned that you changed the configuration of the screens.
The two screen couplers should be just before the MAF (screen coupler, then a short pipe, screen coupler, then the MAF tube).
At least this is how my AEM was configured.
I can't really see much else causing this (related to the intake swap).
Old Nov 27, 2008 | 11:27 AM
What mawd bug?
It was plugged, no vacuum leaks.
I just meant I tried turning the screens around, removing one screen, etc, it's back to the standard config now.
I ran it thismorning with no bogging, however (I hadn't run it after putting the second screen back in last night), so I'm hoping all is good. Will reboot the ECU today.
WranglerFan
Aug 21, 2022 01:29 PM
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
RXFEVER
Sep 11, 2016 02:51 PM
