Heater not working... at all.
Old Nov 17, 2008 | 06:41 PM
SoloMazda8's Avatar
Leisy
At first it would just take a while to get warm, then it would could in and out. Now I have no heat at all. Was thinking maybe the blend door, or maybe the motor for the heater is out. Any help would be great as I'm freezing my **** off!
Old Nov 17, 2008 | 11:49 PM
Mycousinfred's Avatar
yea.. same problem.. I have wonderful Heat one day and now.. it blows only the cold stuff..
this thread here though fixed everything:
DIY: No Heat? Repair the Heater Control
Old Nov 18, 2008 | 02:20 PM
SoloMazda8's Avatar
Leisy
Perfect, thanks.
Old Nov 21, 2008 | 10:57 PM
nichelle's Avatar
No Heat
Hey, I had the same problem. Just replace your heater control module as suggested in other post. Winguit gives a simple test along with the steps for DIY's. My husband and a friend replaced mine much cheaper than the dealership, I even got to help.
Old Nov 25, 2008 | 05:55 PM
Rachlayyy8's Avatar
Same problem
I just got my rx8 from some guy and the heat worked for a little and since i live in fl i never have to use it but its been reallllllly cold the past couple of weeks and the heat doesnt blow heat it blows icecold air almost colder then my ac...any help?!?!?!?
Old Nov 26, 2008 | 03:55 PM
szym0n's Avatar
I had the same prob, my **** for hot/cold temp's was messed up i got hot air only if i played with the **** for like 5 minute until it got into the right spot and it would blow hot air.
Old Nov 26, 2008 | 06:18 PM
04RX8man's Avatar
Rotary Powered Countryboy
make sure your coolant is full also i've seen ppl run aroudn with low coolant and then complain with no heat....
RevMeHarder
Jun 1, 2026 02:30 PM
archon
Oct 1, 2015 06:08 AM
Hunter of Gunmen
Sep 21, 2015 06:27 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
stickmantijuana
Sep 4, 2015 10:31 PM
