exhaust that acts as two different exhausts in one!
Old Sep 25, 2008 | 08:58 AM
srinivasadi's Avatar
Thumbs up exhaust that acts as two different exhausts in one!
I was reading through a JDM blog, when I came across this. You could read the details using this link below
http://www.bespokeventures.com/blog/?p=1295
So basically wat it does is something entirely new. Its an exhaust that acts as two different exhausts in one. There is main pipe which splits into twin. One route is a full straight exhaust with no muffler whatsoever. Another route is through a conventional full titanium muffler for moderate noise suppression. The beauty of this system is that it comes with a remote control so that while inside the car you can decide each day if you want a racing exhaust or a street exhaust on your commute to work.
It would be sweet if someone could come up with a similar exhaust technology for the RX8, it would be awesome.
Old Sep 25, 2008 | 09:11 AM
r0tor's Avatar
hotrodders have been doing exhaust bypass valves for many many many many years now... an uncorked rotary is extremely loud and not very nice sounding
Old Sep 25, 2008 | 09:21 AM
expo1's Avatar
He's as bad as Can
Something like http://www.dmhperformance.com/ ??
Old Sep 25, 2008 | 09:35 AM
Originally Posted by expo1
yeah seems like its the same basic concept. I guess this could also work if you have the valve before the cat right? That way you could have catless and w/cat in the same setup? correct me if I am wrong.
Old Sep 25, 2008 | 09:41 AM
laythor's Avatar
I zoom therefore I am.
So what we’re looking at here is something entirely new. Smoky designed an exhaust that acts as two different exhausts in one.
Someone call the internets police, there's misinformation afoot!
So this is also a cat delete as well, am I seeing this picture right? I'd love to hear a video clip of the difference between running through that dinky muffler and the straight pipe.
Old Sep 25, 2008 | 09:45 AM
dillsrotary's Avatar
jersey fresh
its called a "cut out"
rotarygod's Avatar
I tried a q-tec exhaust cutout on a rotary a few years ago. I started it up and it only ran once! I pulled it right off. There is no power difference and the noise of an unmuffled rotary is downright impressive. The designer of this exhaust apparently doesn't understand that you can in fact have good muffling and good flow at the same time in one system. If he had put a muffler after a valve in the other leg he'd still get the same desired effect from a flow standpoint. Those mufflers are worthless though.
Old Sep 25, 2008 | 10:02 AM
alnielsen's Avatar
There was a time, in the early 80's, that IMSA ran rotary engine cars with open exhaust. I was working corners at road races. It hurt the ears as they went by. The next year there was a DB limit set that the cars couldn't exceed. The tuners said they gained HP with the cars muffled.
Old Sep 25, 2008 | 11:49 AM
matthew121's Avatar
its just a electric cut out. summit sells them
Old Sep 25, 2008 | 11:57 AM
lone_wolf025's Avatar
Future Rotary User
Cutouts are fun toys, but they inevitably burn out in after a few months. In theory its the ideal setup for an exhaust on traditional piston engines as it allows for scavenging at low rpms, then opens to no restriction at WOT. W/out computer control its a pointless toy that does more harm then good.
Hunterkelley24
Jun 14, 2022 08:32 AM
mdl0209
May 23, 2019 05:46 PM
Digitz0070
Oct 7, 2015 12:43 PM
Jb4ker96
Sep 27, 2015 10:06 PM
