Those with a front diffuser, like Seibon, Autoexe, or RE-A
Old Sep 19, 2008 | 02:06 PM
Musker's Avatar
Have you noticed a difference in driving at high speeds?
At 130 mph my car, stock with no appearance package, felt like it needed something to help with aero-dynamics... diffusers should help, right?
The autoexe/seibon front looks like it would actually worsen the effect. Care to Share? Sharing is caring.
Old Sep 19, 2008 | 02:12 PM
nuke0907's Avatar
Never Blend In
WTF are you driving 130mph for?
edit: i just noticed you said you get 130mpg.
Old Sep 19, 2008 | 02:39 PM
czar's Avatar
Almost boosted
...still pretty sure he meant mph... i wouldnt know i havent gone that fast
Old Sep 19, 2008 | 02:51 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
At 130 mpg my car, stock with no appearance package, felt like it needed something to help with aero-dynamics... diffusers should help, right?
I believe that MM tried that and found that it is not sturdy enough. At 153 MPH the car becomes airborne on a straight line, so be careful going above 120 MPH
Old Sep 19, 2008 | 03:03 PM
Musker's Avatar
Yeah the car didn't feel very stable , per se, at 130, and, although I like the look of the auto-exe diffuser, it just looks aerodynamically like it'd create a dam right here:
Obviously, if it makes it worse than stock, I don't want it no matter how good it looks.
I'm just asking owners of this diffuser, or the amemiya one, if they can tell a difference for the good or the bad.
Thanks.
Old Sep 19, 2008 | 03:57 PM
chickenwafer's Avatar
Nope
For me, the car gets a little loose around 125ish, then once you stay in and get past 135 is hunkers down and stays put. I've had it past those speeds and you run out of RPM before the car goes airborne, LOL
Old Sep 19, 2008 | 04:00 PM
Rotr8's Avatar
whines all the way home
I have the Burnout and at 146mph I felt fine,,, spliters act to split the air before it goes under you car to create a better pressure zone for the it to pass undereath the rest of the car...
Old Sep 19, 2008 | 06:02 PM
alnielsen's Avatar
My car felt fine at 125. At 135 the front felt light and I backed down. Lowering springs should keep air from building up under the car and causing lift.
I like the Autoexec front defuser. VIS Racing sells a replica that I may get.
http://www.visracing.com/newcatalog/...duct_info.html
Old Sep 19, 2008 | 10:11 PM
Rotr8's Avatar
uggghh no dodnt get the VIS, horrible product, det it from Siebon, its will still be a replica but its much better in quality.....
Old Sep 19, 2008 | 10:33 PM
burnout front lip. from evo-r. the light feeling from 132 to 138 is gone..
Old Sep 19, 2008 | 11:11 PM
paulmasoner's Avatar
Asshole for hire
seriously? i've been in the mid 150's and not in a straight line(not straight for those speeds) and had no issues. My Shinka is slightly more stable above 120 than other models i've driven hard, but still gets a bit uneasy over 135-140.... fwiw as stated i have the Shinka all stock susp.
Old Sep 19, 2008 | 11:47 PM
imput1234's Avatar
I ♥ Drifting!!!
I've been 138 and never felt that feeling, stock exterior
Old Sep 19, 2008 | 11:52 PM
stock suspension???
that is also a factor..
Old Sep 19, 2008 | 11:54 PM
imput1234's Avatar
I ♥ Drifting!!!
Originally Posted by swoope
stock suspension???
yup, that was like a week after I bought the car bone stock
Old Sep 20, 2008 | 12:08 AM
shaunv74's Avatar
Power!!
At 125 mph it feels good to me even in a high speed sweeper. The only issues I've had are breaking hard from that speed the back end gets really light (for obvious reasons) and wiggles a little.
Full disclosure: I had the Espelir springs on the car at the time so the car was 1.25" lower. That should make a significant difference at speed.
Old Sep 20, 2008 | 08:50 AM
Musker's Avatar
The burnout lip looks like it would work better, but doesn't look as good :P
Decisions, decisions... -_-
Old Sep 20, 2008 | 10:12 AM
Phil's 8's Avatar
I was not saying that the car was unstable or airborne at speeds under 153 just to be careful. I find that my 8 with RB springs, Koni shocks and RB sways really handles well at sustained high speeds ether in a straight line or cornering. My 8 is very dangerous at speed above 150 mph and at 153 can be moved by a lite gust of wind - I would call that airborne. That is the maximum speed I have seen in my 8 and will admit that there was not very much left in it. I feel that just using one of those bolt on deflectors is not a fix for speed issues but just for looks.
Old Sep 20, 2008 | 10:23 AM
Rotr8's Avatar
Look at the authentic Burnout Version II it looks much better than the Version I which is what the Evo-R is, it cost alot more too, and took 3 moths to get here, but it was well worth the wait....
Also- pertaining to the high speed discussion I have
Tien Flex's with a 2" drop
AutoExe Undercar bracing
MS Strut Tower Bars
RB Sways, w/ fr end links
The 2" drop really does help........
Old Sep 22, 2008 | 12:39 AM
SayNoToPistons's Avatar
Wheels, not rims!!
I think you're officially the fastest 4 port AT rx8...
Old Sep 22, 2008 | 01:04 AM
Easy_E1's Avatar
I agree with that.
Mine feels fine at 125 with the Espelir springs on it.
Old Sep 22, 2008 | 10:54 AM
Phil's 8's Avatar
I know of at least one maybe two 6 port 8s that have gone a little faster but had the same results as far as stability.
Old Sep 22, 2008 | 03:36 PM
savedsol's Avatar
Carbonormous
Legsport - actually raced in Japan
Attached Thumbnails Those with a front diffuser, like Seibon, Autoexe, or RE-A-leg-sport-02.1.jpg
Old Sep 22, 2008 | 06:31 PM
Musker's Avatar
But to find it for sale. Now THAT's the tricky part.
Old Sep 22, 2008 | 07:41 PM
kersh4w's Avatar
Hit & Run Magnet
contact japanparts
Old Sep 23, 2008 | 11:03 AM
olddragger's Avatar
i have the yellow konis, tein h springs rb bars and end links. i have a stock front--no appearance kit. No rear spoiler. My car (on the track) does get a little light in the front over 130mph. its a subtle feeling --just does not feel as planted like at 120 and below. the 2009's have more under body paneling and i have been wondering about that.
I just dont want to invest a lot to solve this as the time spent at 130+ is very small. Most times on the track you are not above 100mph.
I have only been on Roebling Road in Savannah since I installed the Pettit system and my debut at Road Atlanta and it's much longer straightaway has me a little concerned. I est at least a 145mph top speed on the back straight. I really dont know if i want to take it that high. You have to brake hard to enter the next turn--a 90 degree one-- and believe me, at 130+ things change.
I am also a little concerned in blowing out the front airdam undertray.
would splitters and or front lip help me noticeably?
follow this thread with interest
olddragger
