Transmission noise
Old Sep 10, 2008 | 06:29 AM
Speedbear's Avatar
Transmission noise
Okay, I've the dealer tells me that the RX-8 "just has a loud transmission." But the more I drive the car, the more it bothers me.
The problem: when shifting into 1st, 2nd and 3rd, I get a pretty loud THUNK most of the time. With the windows down, it really sounds cheap and crappy. It's especially bad when upshifting 1-2 at low RPM. In a parking garage it sounds startlingly loud. I think this is a problem, but the dealer disagrees. Is this normal?
BTW, no, it's not the ABS test, I am well aware of that sound.
Old Sep 11, 2008 | 07:11 PM
813KR$'s Avatar
doesnt sound right to me at all. My tranny is noisey but not like that. mine has a loud throwout bearing and my 4th gear sync is bad, but no clunking as you speak, and I have over 90,000 miles on mine.
Old Sep 11, 2008 | 08:40 PM
kersh4w's Avatar
Hit & Run Magnet
when the car is off, open the door, now hold the clutch down and run through the gears.
does it still make the same noise?
Old Oct 17, 2008 | 06:45 AM
Speedbear's Avatar
kersh4w I never saw your response. There is still a noise but much softer. And now, as I mentioned in my other thread, the noise has progressed to almost a grind when shifting into 2nd at low rpm. ANNOYING AS HELL.
Old Oct 17, 2008 | 05:01 PM
Musker's Avatar
when I go from neutral to 1st from a stop, I hear that same "thunk" sound. It's been like that since the day I bought it (7000 miles).
Also, second gear produces noise from the transmission, like a scratching, and it's been like that since I bought it.
Old Nov 11, 2008 | 05:48 AM
Skyraidr43's Avatar
I have an 05 Shinka and the only annoying noise is when just crusing in 6th between 45 and 60 MPH. The trans just whines when applying power no matter how soft. My 8 is a little hard getting into reverse.
I bought the car used so I don't know how it was when new, only have 23K miles on it, had some minor rear end body dammge that was repaired prior to buying it.
Does anyone else have the whine?
Old Nov 11, 2008 | 07:57 AM
Big Money Pit's Avatar
i think this picture best sums up why the transmission is so loud in the RX-8:
Old Nov 11, 2008 | 08:18 AM
chancejat's Avatar
Drive it like u stole it!
is there any way to reduce tanny noise?
Old Nov 11, 2008 | 08:27 AM
you could try switching transmission fluids, or just asking it nicely to be quiet.
Old Nov 12, 2008 | 07:12 PM
yokohamaboi's Avatar
Tea?
sorry for the thread jack, but my transmission whirls like a super charger, any ideas? especially on cold days. makes that super charger sound going threw gears.
Old Nov 12, 2008 | 07:49 PM
Skyraidr43's Avatar
I didn't understand the pic from "Big Money Pit", I guess he pulled it anyway.
I just want to know if anyone had the noise in 6th. My RX-8 is also a little noisy in the rest of the gears also, but not to bad. 6th is just much louder with little power applied.
I can turn up the tunes but I like the engine sound, I have an 86 RX-7 GXL with 184k miles on it and it still runs and looks very good.
Old Nov 12, 2008 | 08:13 PM
NotAPreppie's Avatar
What am I doing here?
I think the point is that you are sitting almost on top of the tranny.
airlive
Jun 28, 2020 07:46 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
