how to change tail light bulbs?
Old Sep 5, 2008 | 12:54 AM
XlYesterdaYlX's Avatar
Zoom x 2
I've been thinking about getting the LED tailight bulbs...but how do i go about taking out the oem bulbs and replacing them with the LED's?
so it would look like this in the end.
http://www.rx8strakes.com/ProductIma...llight_kit.jpg
Old Sep 5, 2008 | 01:09 AM
StealthTL's Avatar
The standard ones just twist out.
S
Old Sep 5, 2008 | 02:30 AM
Zoom x 2
i know that much...but..how do i go about gaining access to even do that? sorry haha i don't know much about taking cars apart..
Old Sep 5, 2008 | 02:50 AM
Silver06's Avatar
Zoom Zoom....
Since Stealth answered you nicely (didn't say "search" or even "check your owner's manual")
I offer you the following instructions from the Owner's Manual:
Replacing a Bulb (Rear)
Rear turn signal lights, Brake lights/ Taillights, Reverse lights
1. Pull the center section of the plastic retainer and remove the retainers and partially open the trunk side trim.
2. Turn the socket and bulb assembly counterclockwise and remove it.
3. Disconnect the bulb from the socket.
4. Install the new bulb in the reverse order of removal.
If you don't have an Owner's Manual, you can see one online HERE
Look at page 8-32 (257 of the .PDF) - it even has some bad-*** line drawings to help.....
Old Sep 5, 2008 | 02:53 AM
Eight's Avatar
open trunk
unscrew the 4 hooks off of the plastic panel that hold the cargo net
pull the plastic panel upwards to snap the clips that hold it to the body
peel your way through the trunk interior to the taillight sockets.
buy some nice led bulbs, a pair of nice smt leds on ebay for around 25.
install them, and check polarity.
For the turning lights you'll need a resistor which you can also find on ebay usually from the same guy that sold you the bulbs.
Old Sep 5, 2008 | 03:20 AM
Zoom x 2
ah thank you guys!! I really appreciate the info, not knowing how to install of was the only thing holding me back from getting them! Ill be sure to check my manual also!
Old Sep 5, 2008 | 08:31 PM
TheGreatLouisianaRoadkill's Avatar
if you plan to replace the turn singles with LEDs be sure and get some load resistors also. www.rx8strakes.com sells a really good LED kit for the tails.
Old Sep 13, 2008 | 01:53 AM
kainis2k's Avatar
anyone find a good place to mount their load resistors? I got the kit from RX8strakes.com and they're just sitting out at the corner of my trunk trim lol... Aparently they get hot (tested them for like a two minutes and they really do) so I was hesitating on where I wanted to mount them for now...
Old Sep 10, 2014 | 08:39 AM
curly_drift08's Avatar
anyone get this LED kit ? I just wanna know if its worth the money
Audio Concepts ATL
Sep 26, 2021 01:59 PM
coolcars44
Nov 29, 2017 05:45 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
MarkX
Jul 31, 2015 07:50 AM
Stubbs
Jul 28, 2015 09:23 PM
