Royal Purple trans fluid?
Old Aug 31, 2008 | 02:41 PM
WTBRotary!'s Avatar
Drummond Built
Question Royal Purple trans fluid?
Ok so where do yall ( pardon my slang, < Texas) get your Royal purple tranny fluid? Ive looked and so far autozone doesnt seem to have it... i need some Royal Purple MAX-ATF Automatic Transmission fluid. Any suggestions in where to get some?
Old Aug 31, 2008 | 03:08 PM
StealthTL's Avatar
Cool
I never get tired of this picture!
Sorry it doesn't help.....
S
Old Aug 31, 2008 | 03:09 PM
BOB9995's Avatar
http://www.royalpurple.com/index.html
The above is the Royal Purple web site, which has a dealer locator. Hope this helps.
BOB9995
Old Aug 31, 2008 | 03:12 PM
TopGear8's Avatar
mkuhnracing.com
same place you get a new transmission when you put royal purple in it....
Old Aug 31, 2008 | 03:14 PM
WTBRotary!'s Avatar
Drummond Built
heh yeah, i looked at the dealer locator and it shows autozone and a few other but i dont see any of them having it... >_<
Old Aug 31, 2008 | 03:15 PM
Spinning Sushi's Avatar
I <3 Sushi
The ATF fluid from Royal Purple is fine in the AT Transmissions.
Old Aug 31, 2008 | 03:29 PM
Charles R. Hill's Avatar
Owner of BHR
I can get you the RP as well as Eneos A/T fluid.
Old Aug 31, 2008 | 03:32 PM
WTBRotary!'s Avatar
Drummond Built
You can get me some? that would be great, heh cus im at 50,000 miles so i think its about time to redo the fluids on the ole tranny
Old Aug 31, 2008 | 03:49 PM
WTBRotary!'s Avatar
Drummond Built
Im also hearing alot of problems with RP transmission fluid... But i have no idea if its the auto or manual fluid...
Old Aug 31, 2008 | 03:57 PM
NgoRX8's Avatar
all the complaints come from manual owners. we don't get a lot of talk here about changing the auto transmission fluid.
Old Aug 31, 2008 | 04:06 PM
WTBRotary!'s Avatar
Drummond Built
ok good... heh cus i was kinda iffy if i should get some...
Old Aug 31, 2008 | 04:09 PM
Owner of BHR
I am thinking 20-25K would be more the norm.
Old Aug 31, 2008 | 04:14 PM
WTBRotary!'s Avatar
Drummond Built
yeah, so its about time... just need the damn fluid now lol
Old Sep 1, 2008 | 12:15 PM
dothackRAVE's Avatar
&lt;3 Rotary
RP MaxGear seems to work fine for me. I also just went 5w30 Royal Purple for the engine.
We'll see how this goes, but it's noticeably smoother and faster. If both engine and trans go kaput, I'll go get myself some better stuff from non-Mazda sources.
Old Sep 1, 2008 | 12:22 PM
WTBRotary!'s Avatar
Drummond Built
thanks bro but < Auto, well for the fluid im just gonna use Royal Purples ATF but for oil i was thinking about 5w30 royal purple engine oil but i just got a new engine so im gonna keep it on the safe side and use non-syn for the first 1,000-1,500 miles.
Old Sep 27, 2008 | 07:31 AM
Amsoil makes the best auto trans fluid, the best ... several big dealers in Tejas
Old Sep 30, 2008 | 01:49 PM
rled's Avatar
5Picker
I agree.They make the best gear lube period. Check this out. http://www.amsoil.com/products/gearl...hitePaper.aspx
Old Nov 17, 2008 | 03:13 PM
BOB9995's Avatar
RAVE
WOW! There has been many heated discussions on this web site, about using syn or dyno in early 8s, the ones prior to 05. I'd love to use RP in my VR 04 if I could without doing harm to engine seals. Right now I use Castrol GTX 5w-30 which has been great so far, also I add IDEMITSU Rotary Premix to my gas tank for added protection of the seals. This premix is a synthetic blend fuel lube, but you probably already know that. If you would, please let me know how you make out with the RP engine oil.
Many Thanks
BOB9995
Old Nov 17, 2008 | 04:16 PM
Owner of BHR
Originally Posted by BOB9995
I'd love to use RP in my VR 04 if I could without doing harm to engine seals. If you would, please let me know how you make out with the RP engine oil.
I just rebuilt an '04 engine that used RP since Day One and had 17,000 miles on it. There was no strange issue with the synthetic not burning in the housings and the bearings and clearances looked real good. I still would suggest the use of the Sohn OMP adapter to use 2-stroke oil for the injection circuit and whatever oil you want for the engine bearings.
Old Nov 17, 2008 | 05:21 PM
04RX8man's Avatar
Rotary Powered Countryboy
So are we deciding that RP is not the best for tranny? Is redline better. I am just beginning to get some hardER shifts than usual and figured going to a synthetic trans fluid would b good.......I'm just not sure weather to use RP or Redline....
Old Nov 17, 2008 | 05:59 PM
Owner of BHR
RedLine seems to be the popular choice around here. For me, I have always used Mobil1 75W90 and never had issues with it. I am currently trying out some Eneos 75W90 and it seems pretty cool. The current/popular wisdom is to make sure to use GL-4 rather than GL-5, though, and Eneos is a GL-5.
Make sure to research the issue of broken clutch pedals, too.
Old Nov 18, 2008 | 06:49 AM
&lt;3 Rotary
AFAIK, RP Maxgear is both GL-4 and GL-5. I do notice that the shifts are a lot smoother with RP, but I don't think it holds up to heat very well (after a while under racing conditions, the 2nd gear synchro starts acting up). I'll flush it out and use another round of RP Maxgear before I decide if its really Maxgear being a bitch, or something else entirely.
Old Mar 18, 2009 | 01:22 AM
living the dream's Avatar
PA
i also have the problem with the 2nd gear synchro acting up!
i changed mine 1000 miles ago (royal purple 75-90 max gear)
i personally think it may be to thick?
anyone else have this problem? and anyone figure out a solution..
i am about to drain it out and go to redline..
i cant risk breaking a synchro..
dothackRAVE- how long have you had your royal purple running through your car?
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
bosstin87
Oct 5, 2015 06:52 AM
XianUnix
Sep 29, 2015 03:48 PM
