Squealing Belts
Old Aug 29, 2008 | 12:16 AM
Rootski's Avatar
DGAF
Squealing Belts
When my car sits for awhile in warm weather, and then I start it up, I get this horrible loud belt squeal. I'm fairly certain it's in the A/C belt, but I could be wrong. Either way, it goes away as the engine itself warms up, but until it does it begins to squeal at progressively higher and higher rpms (it'll stop squealing at idle, but start again when I rev to 3000... then go quiet again until 4000... and so on until the car's been running for a while and they stop entirely). My hypothesis is that the warm weather is making the belts soft and looser, and I need to tighten them. But it doesn't make sense that they stop when the engine warms up then. I've also heard belts will squeal because they're overly tight. So what do I do? Tighten, loosen, or something else I haven't thought of?
Old Aug 29, 2008 | 12:27 AM
Easy_E1's Avatar
Actually the belts are cold ( comparatively speaking) when you start it up. Then the slipping that occurs warms them and softens them. And they stick better. Kind of like a race car tire.
You might try tightening them a little bit.
Old Aug 29, 2008 | 01:20 AM
paulmasoner's Avatar
Asshole for hire
rootski, i had almost exact same symptoms... tighten A/C belt just a bit, worked for me
Old Aug 29, 2008 | 09:09 AM
EDZRIDE's Avatar
2005 White GT
Turn the A/C off before starting the engine.
Old Aug 29, 2008 | 09:12 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
And then turn it on................if it squeals, then you know it's the A/C belt. Tighten it just a little and see if goes away.
Luke.s
Sep 30, 2015 05:57 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
tommy26Germany
Sep 29, 2015 10:33 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
cgrichie
Sep 19, 2015 07:03 PM
