A/C Compressor cuts out
Old Aug 17, 2008 | 09:07 PM
04nordicgreenrx8's Avatar
Hello,
I have an ''04 RX8 6-Speed with 38K miles.
I am having a situation where my A/C compressor seems to cut out randomly. I will have no problems for 1 week, then one day when I start the car the compressor does not run and I am blowing hot air! The next time I start the car (later in the day), the compressor is working fine and blowing cold air again. This is not a freon issue, since I would expect to have a drop over time on the cooling - not this on/off issue.
Has anyone experienced this? I am currently out-of-warrenty, so I know that bringing this issue in for service will cost me.
Regards, Rob
Old Aug 17, 2008 | 09:09 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Sounds like you need a new AC computer. They had to replace mine.
Old Aug 18, 2008 | 06:30 PM
Pin8's Avatar
Try making sure the temperature gauge is all the way on cold . Give it a little nudge past where it normally stops. That works for me.
Old Aug 19, 2008 | 07:45 PM
Your simple fix works!
Pin8,
I tried that and it works! Did you replace your **** as a result of this? Is there a way to make an adjustment to the **** to correct the problem?
Regards, Rob
Old Aug 20, 2008 | 12:54 PM
the **** is the issue?! somehow I think there's a bigger issue here but glad to hear it's fixed
Old Aug 20, 2008 | 01:32 PM
Pin8's Avatar
I didn't replace the ****. I got that idea from another thread here. I don't know if you can adjust the **** but if your still under warranty I think that they should replace unit for you. It seems that has been done for others here.
Old Aug 20, 2008 | 07:52 PM
Unfortunately, I am out of warrenty. That is why I am trying to narrow this down since I will make the repair myself.
Old Aug 20, 2008 | 11:05 PM
I belive yours may be normal. do a search and you will find the cabin is too hot from the engine and tranny for the A/C to compensate.
Old Aug 20, 2008 | 11:13 PM
my A/C keeps the cabin nice and COLD.
Old Aug 20, 2008 | 11:14 PM
Except when its 90 plus or your driving from stop light ti stop light.
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
D13
Oct 1, 2015 07:55 AM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
