Shudder at cold start?
Old Nov 25, 2003 | 10:49 AM
DRx's Avatar
DRx
I decided to post this after reading the thread on people getting new engines after 1000+ miles due to coolant leaks...
Is this something you guys see? When you cold crank (like first thing in the morning or after your car has been sitting for a few hours) do you notice a very slight 'shudder' in the engine idle? It lasts about 1 second but is very noticable... after that the idle smooths out until the engine is warmed up. This happens every time, only at cold start.
Also, I have noticed when I accellerate quickly between gears, that if I give it a lot of gas the engine almost seems to lag a half a second or so before the power kicks in. It's like it isn't combusting immediately or something. Anyone else noticed this?
Old Nov 25, 2003 | 10:52 AM
matt's Avatar
I have noticed the same thing on my morning start-up. Usually with the outside air temp below 60 degrees.
I am not sure if it's common or not. I am new to rotories.
Jaco Greyling
Jan 6, 2019 08:39 AM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
Redheddude222
Aug 24, 2015 09:14 AM
Solmors
Aug 21, 2015 10:11 PM
dbarber
Jul 25, 2015 01:34 PM
