Front End Rattle
Old Jul 21, 2008 | 04:31 PM
fahrfegneugen's Avatar
Front End Rattle
So I have searched, and it seems to me that I might be able to suspect that my endlinks are causing this metal on metal sound when I go over a decent pothole or something. I took the wheel off yesterday to look for something, but nothing was loose feeling except this little control arm, so I tightened it up, and then I got a light for the automatic head light adjusters. However, the rattle got quieter, for a bit, then it got worse so I took the thing off and it got way better, but the rattle is still there...
Any ideas...?
My other question is, if it is the endlinks (I'll just get stock ones), does it matter much how much I torque them, any specs on that?
Old Jul 21, 2008 | 07:22 PM
gundarx's Avatar
Hummmmm...
Hmmm funny how you got this problem. I spotted this on Finishline just this weekend:
NOISE FROM FRONT OF VEHICLE / STABILIZER CONTROL LINK BROKEN
If it is that, take it in for warranty. It affects all 8s until the 2008 models.
Old Jul 21, 2008 | 07:30 PM
Wish I had my full warranty still
Old Jul 21, 2008 | 07:40 PM
gundarx's Avatar
Hummmmm...
At least you have an idea what's going on
BTW, what sort of sound does it make when you hit a pothole? I've been cruising more with the windows down lately and on some particular roads that have an echo effect, I can hear a quick metal-to-metal contact sound from the suspension on broken pavement- I had been thinking that it's normal mechanical noise from a precision-tuned suspension (hey this is my first sports car) or something along that note LOL.
Old Jul 21, 2008 | 07:47 PM
It is a metal on metal sound that is coming only from the driver side wheel it seems.
kinda of a higher pitched: clinkity tank
It should be quite basically, I don't know about your metal on metal sound, hmm... What do you mean an echo sound? Like a hollow low pitched noise? that should be normal.
Old Jul 21, 2008 | 08:41 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah stabilizer link if it's under warrnaty/recall/tsb have the dealer do it for free if not and u just end up buying one I always torque all stabilizer links down as tight as i can safely get them......
Old Jul 21, 2008 | 09:05 PM
gundarx's Avatar
Hummmmm...
Sorry if I threw you off with the "echo" note.. I meant that there are some roads that have dividers/walls to my left (driver's) side that effectively bounce the car's engine sound (and suspension sound in this case) back to me. Kind of like going in a tunnel
The only sound I'm hearing from the suspension is from the inbound stroke of the spring/strut and there is only once sound/note for each significant dip in the road. It sounds like a metal click.
Am I just being paranoid? I've only driven cars with rubbery suspension prior to the 8 so this could just be normal hehe..
Old Jul 24, 2008 | 12:35 PM
I don't think I have ever heard a click, but if it is faint, I honestly doubt you should ever worry about. The echo might just be the tires too.
Old Jul 24, 2008 | 10:59 PM
gundarx's Avatar
Hummmmm...
Cool. Thanks man.
Old Jul 24, 2008 | 11:16 PM
mine are already apart, I checked. it doesnt effect me too much as long as Im not too aggressive
Im waiting for a clear sunny day with a cool breeze around 70 degrees. then Im gonna head out and replace the end link with Autoexe adjustable ones + install the new autoexe sways.
Old Mar 16, 2011 | 06:38 AM
Mr Franco's Avatar
The noise you are hearing I think is the brake and Disc protector the flimsy bit of metal around that area. My last 2 RX8's have both had this noise and I just bend that plate a little back and it goes away but still comes back. Drives me mental, thinking about just removing it.. Good luck I hope this works for you and other worried 8 owners...
Old Feb 23, 2012 | 07:30 AM
iMotoPilot's Avatar
I just purchased my 05 RX-8 yesterday and noticed a high pitched rattle from the frontend when going over bumbs and potholes. Strange enough it goes away after a while. I did a walk around and noticed the plastic "Gill" insert in the fenders are really loose. Normal?
Old Mar 18, 2012 | 08:53 PM
iMotoPilot's Avatar
Rattle from Skid Guard
Rattle / Squeak hunting. 2005 GT - Found a possible source for some of my under carriage rattles that my local garage can't seem to pin point. Can anyone tell me what size bolts or fasteners hold the plastic skid guard? These seem larger than the side bolts. Photos to come in a bit
Old Mar 18, 2012 | 09:51 PM
Darkning's Avatar
^^+1
I had this exact thing, it's a very tinny clanging rattle sound and just as Mr Franco said it's the stone guard/brake rotor protector thing. I just got a screwdriver and pressed inward towards the engine bay on it at the edge and bent it away from the wheel and it went away.
Old Mar 19, 2012 | 12:37 AM
dalen2000's Avatar
Wish I had my full warranty still.
Old Mar 19, 2012 | 01:02 PM
Pendleton's Avatar
Roto-rookie
I too had a very clanky noise every time I hit the slightest bump. It turned out that my brake pads had no shims and were slapping around. As soon as I bought some shims and installed them, the noise disappeared. Then I discovered that those little silver brackets that the pads' tabs fit into are also a source of noise because they also tend to move around, at least on my car they do. They would make kind of creaky-creaky sound when I applied the brakes. I dobbed a little high temp silicone on the bottom of each of those brackets and stuck them back into place on the caliper. It's all nice and quiet now.
Edit: Didn't realize the original post was so old. Hopefully somebody gets something useful out of this.
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
