Shift Point Technicques
Old Nov 22, 2003 | 09:45 PM
RenesisPower's Avatar
I am interested in your comments on the three shifting techniques with the Renesis. As we all know this motor's output is:
238 BHP @ 8,500 RPM
159 ftlb @ 5,500 RPM
1) MAXIMUM PERFROMANCE
Shift at 8,500 or above(above to compensate for RPM drop while clutch is depressed). You get best acceleration and overall perfromance with poor fuel economy.
2) BEST BALANCE
Shift at 5,500 RPM(max torque), get good perfromance while maintaining good fuel consumption, best overall balance in everyday driving.
3) BEST FUEL ECONOMY
Shift at 3,000 RPM, slow but helps the dreaded fuel economy of the Renesis.
Old Nov 22, 2003 | 10:45 PM
syntrix's Avatar
I like cheese!
None of the above.
If you have access to a dyno source data, there are many shift plot excel spreadsheets on the net.
What works best for 1-2 may not work the best for 4-5.
I still have yet to look into this, but it has to deal with the power curve, and how it tapers off near redline.
do a google and you will find some.
Old Nov 23, 2003 | 01:37 AM
eccles's Avatar
Prodigal Wankler
The optimum shift point occurs as the available torque tails off to the point where there is more torque available at the wheels in the next gear. However, the relatively flat torque curve of the Renesis, combined with the ratios in the RX-8 6-speed, mean that there is no point where this happens in any gear.
See this post for a set of cascades which illustrate this point. If the curves intersected, the intersection point would be your optimal shift point, but since they do not, your optimum shift point for performance is as the redline in every gear.
Old Mar 8, 2006 | 02:19 AM
Detrich's Avatar
幹他媽!
i read in this week's autoweek about them doing acceleration trials on the v6 corvette. and, they said that by shifting into 2nd gear sooner (ie not waiting for 1 to redline i guess), they were able to get 0-60 under 6 seconds. the reason was because the vette's 2nd gear really is where all the power boost is at.
does the 8 have something similar for us to do? does anyone know?
Old Mar 8, 2006 | 04:45 AM
StealthTL's Avatar
Usually.....
The max torque point on a motor usually coincides with the peak volumetric efficiency, which is where the motor is sucking air/fuel the best, so it is not conducive to best economy. I remember something about Nascar drivers having to back off the throttle as they passed the max torque area, to avoid tranny "overstress".
During some of Canzoomer's early explorations of the power band, he noted the mixture got really lean, with lots of power, between 5500 and 6500 rpm. I ran a whole tank of gas at those revs, so basically never getting into 6th or even 5th gear even on the highway . Fuel mileage didn't improve, but it was really a LOT of fun!
S
Old Mar 8, 2006 | 07:34 AM
yiksing's Avatar
the giant tastetickles
Spot on...
Old Mar 8, 2006 | 12:50 PM
Detrich's Avatar
幹他媽!
Fastest way to shift for shortest 0-60 time...
so... are u saying that for the rx-8, if we want to get the fastest acceleration for 0-60 we should keep the car between 5500-6500 rpms?
who is canzoomer? is he just some guy or do we have info on this subject from some sort of authoritative source?
thanks for the info.
S
Old Mar 8, 2006 | 11:22 PM
yiksing's Avatar
Just keep it in the rpm range between peak torque and peak hp, lots of shifitng work but fun and challenging.
Old Mar 9, 2006 | 12:28 PM
Nubo's Avatar
Lubricious
Amply illustrated in this video
http://video.google.com/videoplay?do...=%2B%22rx-8%22
Old Mar 9, 2006 | 09:53 PM
bd32322's Avatar
the driver has to shift at a point *after* the point of max horsepower - correct? and not shift *at* the horsepower peak. Because, after the shift, the rpm drop will still keep him closer to the peak power point than if he shifted at the peak power.
So maybe thats why he is going past approx 8.5k (understand peak power depends from car to car - but approx its at 8.5k).
Just my guess.
Bodi
theblinkof
Oct 4, 2023 05:24 PM
Hunterkelley24
Jun 14, 2022 08:32 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
XianUnix
Sep 29, 2015 03:48 PM
