Caliper Questions (help)
Old Jul 16, 2008 | 05:21 PM
klittl06's Avatar
Today I rebuilt my caliper because my brake pads were constantly against my rotor. Well after cleaning my after pretty clean caliper, I think that I am maybe missing a bracket or something.
This was my first time working on the brakes, so I can only guess.
Heres what I have, one bracket behind each pad and I have the two brackets (top & bottom) that attach to the caliper bridge. But I don't see anything that would make the brake pads return after the piston presses it against the rotor.
Any help and/or ideas are welcome.
Old Jul 16, 2008 | 09:10 PM
RebelYJ's Avatar
I'm not sure how the 8's brakes are (haven't gotten mine yet), but the in a disc brake setup the brakes pads are always on the rotor, at least within an few thousandths of an inch.
And I don't get what you mean by the pad is on the rotor; does it slow you down when you're driving without applying the brakes?
Old Jul 16, 2008 | 10:30 PM
ken-x8's Avatar
Originally Posted by klittl06
...This was my first time working on the brakes, so I can only guess...
What info/instructions did you follow when you rebuilt the calipers? That would have shown all the parts.
Disc brakes don't have any kind of return mechanism. When your foot is off the pedal, the pressure is off and the pads tend to bounce clear on their own. Very different from drum brakes, which are booby-trapped with all kinds of springs.
Ken
Old Jul 17, 2008 | 02:50 AM
Nopstnz8's Avatar
Are you talking about the anti-rattle clips? They are the metal clips you can see when you look at the caliper when it is attached to the rotor. If that is what you are missing, I wouldn't worry about them since they just lessen vibration and noise, not performance.
Old Jul 17, 2008 | 11:02 AM
klittl06's Avatar
I wasn't sure if there was another piece that I was missing.
Before I cleaned my caliper my rear passenger brake would grind on the rotor. Hopefully once I bleed my brake line it will be okay.
My caliper was very clean, so I though maybe I was missing a part and that was the problem..
Old Jul 18, 2008 | 10:57 AM
klittl06's Avatar
After bleeding my brake line, everything was fine.
Thanks to all who had input.
jer2911
Sep 29, 2015 06:37 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Austin22
Sep 23, 2015 04:46 PM
TheRedRotor
Sep 22, 2015 05:30 AM
Wurromurro
Sep 20, 2015 05:02 PM
