How do I remove the cap on my oil?
Old Jul 15, 2008 | 08:28 AM
Leesha's Avatar
View at your own Risk :)
Hi all...
It can't come off! What am I doing wrong?
Old Jul 15, 2008 | 08:32 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Righty tighty...........lefty loosey.
If it hasn't been off for a while it might be tight.
Putting a small towel over it might help and get some more leverage.
Buckle down girl and get made at it.
Old Jul 15, 2008 | 08:33 AM
dillsrotary's Avatar
jersey fresh
lightly tap it with a hammer
Old Jul 15, 2008 | 08:36 AM
Footman's Avatar
Dodging those Corollas
For my car, it's right to loosen, and left to tighten.
Old Jul 15, 2008 | 08:37 AM
Mazurfer's Avatar
Really?
Standing in front of the car?
Old Jul 15, 2008 | 08:38 AM
Leesha's Avatar
What? No for real...it is on so tight that I can't get it off!
Old Jul 15, 2008 | 08:40 AM
Footman's Avatar
Yeah, it's standardized...
Old Jul 15, 2008 | 08:43 AM
Leesha's Avatar
Okay will it break if I try harder?? My son tried and I'm afraid to break it... ok will try the hammer thingy... If it breaks...I'm not coming back here... I'll do it lightly...
Mazurfer's Avatar
Could Canada be different?
I'm not crazy..............I swear.
Old Jul 15, 2008 | 08:46 AM
Mazurfer's Avatar
Drive around the block and get one of those cops that like you so much to help out.
I can't recommend using vise-grips or anything other than just torquing by hand. You might be able to tap lightly, but I'd be careful.
Old Jul 15, 2008 | 08:54 AM
Leesha's Avatar
Ok it didn't work!! Damn...
Old Jul 15, 2008 | 08:58 AM
Footman's Avatar
use science...
drive aroudn the block so the engine bay is heated nicely. Then open the hood. take a can of compressed air ($5 or free depending where you swipe one). hold the can upside down, and empty like half the can or more onto the neck of the oil cap only. The neck should shrink microscopically while the oil cap is still expanded from the heat giving you several hundred extra micron's of wiggle space. Hopefully the cap will then loosen easier.
Old Jul 15, 2008 | 08:59 AM
Footman's Avatar
WAIT sorry... backward directions....
the oil cap threads INSIDE the neck as opposed to on the outside like a jar....
Spray the compressed air upside down on the OIL CAP DIRECTLY, and NOT the neck!
Old Jul 15, 2008 | 09:05 AM
Leesha's Avatar
Ok I'm not doing all that...
I still need to do the recall so I just called the dealer and I'll book the oil change at the same time... I also mentioned to them how tight it is... & am trying to get a replacement car while mine is being fixed...
Old Jul 15, 2008 | 09:09 AM
Footman's Avatar
lazy...
Old Jul 15, 2008 | 09:19 AM
Leesha's Avatar
LOL...first of all...I don't know what I'm doing or how to do that so before I hurt my baby... I'll let the dealers take care of it...
Will it come off easier if the car is hot??
Old Jul 15, 2008 | 09:37 AM
Footman's Avatar
You are taking a can of compressed air, holding it upside down to freeze the oil cap. Since the cap is threaded on the inside.
From science, heat expands, while cold shrinks. The idea is to shrink your oil cap by several hundred microns, while the neck of the oil filler is still hot (expanded).
If the outside is expanded while the inside is shrunk, you may have a chance at removing the oil cap easier.
Old Jul 15, 2008 | 09:38 AM
Footman's Avatar
You can't hurt a cap with the kind of freezing done by an upside down can of compressed air.
Old Jul 15, 2008 | 09:50 AM
Leesha's Avatar
Have you ever tried it? I'll take the easy way out thanks... Or why not just put ice on the cap...???
Old Jul 15, 2008 | 09:55 AM
Footman's Avatar
The time it takes for ice to cool your cap down is not fast enough before the neck of the oil filler will also start cooling down.
What you are seeking is a large temperature delta between the cap and the neck portion. The closer in temperature the two items are, the more "fitting" the cap will be. You don't want that.
Old Jul 15, 2008 | 09:59 AM
SlowLude's Avatar
You just have to turn the cap like a bitch counter-clockwise (to loosen hopefully). I know how tight those damn dealers put them on sometimes. Just use a bit more muscle.
Old Jul 15, 2008 | 10:02 AM
Leesha's Avatar
Trust me...my son tried and we are afraid of breaking it!
Old Jul 15, 2008 | 10:39 AM
qtwre's Avatar
Footman, you're such a nerd.
I would have loved to be the first one to reply to this so I could answer the topic question with "Get a man to do it".
There's no special voodoo required to open the cap. Just twist it left (counter-clockwise) as mentioned, HARD! It's a machine, not a baby. What is the dealer mechanic going to do when you bring it over? He'll turn it really hard. lol
If it breaks, I owe you a coke.
Old Jul 15, 2008 | 10:51 AM
dozer's Avatar
on his 3rd rx8
leesha!!!! HA!!!!!!!!!!!!!!!LMFAO!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 15, 2008 | 11:15 AM
Easy_E1's Avatar
That's what she said when the bed broke.
