CEL on after intalling AEM intake and SRmotorsport pulleys kit
Old Jul 13, 2008 | 01:38 PM
lancer's Avatar
the CEL is flashing and sometime stay on for a while after I intall the AEM intake and Pulley set. any of you have any ideas about this or what could I have done wrong to cause the CEL flashing.
Old Jul 13, 2008 | 01:50 PM
Socket7's Avatar
ಠ_ಠ
uh. I think you need to reset your eccentric shaft sensor. I'm sure there are threads here that will not only tell you exactly what you need to reset after installing pulley's, but also how to reset it. Search and you will find everything you need.
Old Jul 13, 2008 | 05:33 PM
Jon316G's Avatar
Grasshopper
^+1
I had to do that after my pulley install.
Old Jul 13, 2008 | 05:53 PM
lancer's Avatar
I will do that. thank guys
Old Jul 13, 2008 | 06:05 PM
lancer's Avatar
I searched, and most of the link to the 20 pedal stomp do not work. any of you have the link to this step..
Old Jul 13, 2008 | 06:09 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
No, but here's what you do.
Turn the key to on, but do not start.
Stomp brake pedal about twenty times(quickly) while watching the oil pressure needle until it sweeps all the way to the right and then back. If doesn't sweep, turn off, wait, and then start over.
Turn key off.
Start car as normal, if it's still on, then start over.
Remember to not shut the car off when it's cold.
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
