DIY on testing OEM coils
Old May 25, 2008 | 11:36 PM
turborx8's Avatar
Boost 4 Life
I have a voltage meter and I would like to make sure my OEM coils are perfect.
Here is the procedure I found in the service manual but what settings do I set my voltage meter at?
Old May 25, 2008 | 11:40 PM
Easy_E1's Avatar
I tried the "Search" function and came up with this,,
https://www.rx8club.com/showthread.p...t=coil+testing
Doesn't mean that the coils could not be failing during high rpm operation.
Old May 25, 2008 | 11:41 PM
mysql's Avatar
Doppelgänger
it's really a crap shoot with the oem coils.
That's why I ended up just replacing them once a year.
Old May 26, 2008 | 12:00 AM
xsnipersgox's Avatar
One Shot One Kill
u would set it on resistance, the omega looking thing. as low as possible on the range for the test on no resistance (basically testing that the lines are touching).. on the million/OL. you are testing that the 2 terminals are not touching. i doubt this will be everything for a coil, but it's really the only "test" that can be quantified.
Old May 26, 2008 | 12:11 AM
turborx8's Avatar
Boost 4 Life
I did that and I keep getting a reading of 1.
I switched the setting to "->+" and I got the following readings on termials A/B
Coil #1 - 507
Coil #2 - 512
Coil #3 - 504
Coil #4 - 509
I switched the setting to "->+" and I got the following readings on termials C/B
Coil #1 - 429
Coil #2 - 427
Coil #3 - 428
Coil #4 - 430
I got the following readings on termials C/A
Coil #1 - 504
Coil #2 - 509
Coil #3 - 509
Coil #4 - 506
Just replace it every 20K miles or so. Not that expensive. consider the gas prices now, for the price of 2 fillups u get a brand new set of coils
Old May 26, 2008 | 12:31 AM
turborx8's Avatar
Boost 4 Life
Not if you live in Canada.
The local dealerships here charge insane prices.
Old May 26, 2008 | 12:35 AM
really ? how much do they charge ?
if its really too much, u can ask around and see if someone willing to do the *shipping* work for u (me, for example)
Old May 26, 2008 | 12:51 AM
Jon316G's Avatar
Grasshopper
The ">+" symbol is for testing diodes... use the symbol that looks like a "horse shoe" which is the symbol for Ohms that you will use to measure resistance.
Basically... you want the multimeter to show resistance... this will tell you that there isn't a short within the coil. Here is what I measured when I pulled my coils:
Terminals A/B measured 1.6 - 1.7K
Terminals C/B and C/A measured 2.5 - 2.6M.
Old May 26, 2008 | 12:57 AM
turborx8's Avatar
Boost 4 Life
I have multiple ohm settings on my meter.
2000 K
200 K
20 K
2000
200
I set the meter to 20k and I got the following readings on terminal A/B
Coil #1 - 1.53
Coil #2 - 1.58
Coil #3 - 1.56
Coil #4 - 1.57
I can't get a reading with C/B and C/A wiht my meter set to 20k ohm. It just displays "1"
Old May 26, 2008 | 01:05 AM
Jon316G's Avatar
Grasshopper
You got a 1 displayed because you were trying to measure resistance that was ~2.5M with the meter set to 20k.
You need a meter that can measure more than 2M ohms
FYI... 2000k = 2MB ohms
Old May 26, 2008 | 01:16 AM
turborx8's Avatar
Boost 4 Life
Now I understand.
Thanks man!!
Old May 26, 2008 | 11:50 AM
turborx8's Avatar
Boost 4 Life
I called two local dealerships and they both had the same price.
$101.12 each
Old May 27, 2008 | 11:34 AM
kersh4w's Avatar
Hit & Run Magnet
http://finishlineperformance.com/sto...cat=338&page=1
$26
i dont see why they wouldnt ship to canada. PM me if they dont, i'll help you out.
Old May 27, 2008 | 12:13 PM
$101.12 each
ROFL ?! 101.12 EACH in CAD ????????!?!?!?!?!?!?!?!?!?!
If tommy or jason cant do canadian shipment, I can freaking get it for you. pay me the cost /w shipping and thats it. u can actually buy a few more sets cuz u will need it in the future anyway.
Old May 27, 2008 | 07:43 PM
kevinD1226's Avatar
wow u can get the ignition solution for just a little more
Old May 27, 2008 | 08:48 PM
Jon316G's Avatar
Grasshopper
I just noticed that he (turborx8) has the MazSport Ignition Solution listed in his bio (or whatever you call that field at the bottom)
Were you just curious if the stock coils were bad?
ASH8
20
Sep 26, 2022 11:55 PM
RayBarron
Oct 19, 2015 08:08 PM
PotatoCannon
Sep 6, 2015 11:48 AM
madrotor
Jul 26, 2015 12:06 PM
dbarber
Jul 25, 2015 01:34 PM
