TPMS light on
Old Nov 15, 2003 | 05:35 PM
KC_RX-8's Avatar
TPMS light on
I have just installed aftermarket 18's on my stock tires and the TPMS light has cam on. I have tried to do what the manual says but no luck. Any other suggestions?
Old Nov 15, 2003 | 05:53 PM
mikeb's Avatar
100% Italian
sorry, cant help there
but how about some pics of those enkei's
Old Nov 15, 2003 | 07:25 PM
OUR X 8's Avatar
Did you install the sending units on your new wheels?
Old Nov 15, 2003 | 07:32 PM
KC_RX-8's Avatar
Yes
Old Nov 15, 2003 | 07:40 PM
OUR X 8's Avatar
hmmm.......
Old Nov 16, 2003 | 09:30 AM
KC_RX-8's Avatar
so i guess no one has got any advice for me?
Old Nov 16, 2003 | 11:03 AM
rx8cited's Avatar
Perform Wheel Unit Auto Registration
Hi KC_RX-8,
I've got some ........ if the TPMS warning light is flashing, then try the following:
Look at "Tire Pressure Monitoring System Service Tips"
http://www.finishlineperformance.com...02-002-03.html
Assuming you do have the TPMS wheel units (sensors) installed on all wheels, you should just have to do step 3 "Perform Wheel Unit Auto Registration" under the "Replacing a TPMS wheel unit" section (bottom of document - or http://www.finishlineperformance.com...2-002-03-5.gif ) .
Just curious, which wheels and sensors (Mazda?) are you using ?
Let us know if the above fixes the problem.
Good luck,
rx8cited
Old Nov 16, 2003 | 11:23 AM
CraziFuzzy's Avatar
You are sleeepppyyyy.....
Is the light on or flashing? if it is steady on, it means it is seeing the pressure as too low or too high. If it is flashing, that means it is seeing a problem with the sensors, and probably doesn't recognize them. What pressure do you have the tires inflated to?
Old Nov 16, 2003 | 07:22 PM
KC_RX-8's Avatar
the light is just on, not flashing.
Old Nov 17, 2003 | 11:07 AM
XeRo's Avatar
Normality is Obscene
pump those suckas up!...or let some air out....either one of these should set you straight,.,.i think someone stated that already...oh well..
Old Nov 18, 2003 | 12:44 PM
KC_RX-8's Avatar
HAHAHAHA!!! thanks XeRo!! that was it, too much air!!! no more light!!
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
