new exhaust
Old Apr 30, 2008 | 10:38 PM
t-rex04's Avatar
new exhaust
hey everybody here"s some new pictures of the exhaust work i just had done. I did 3" pipe from the catalytic converter back with two magnaflow straight through mufflers part #14419 (they're a round muffler they're 4"s wide and have a body length of 14"s) I might add a third before the Y pipe to quiet the exhaust down a bit. I might not though not too sure just don't want to get pulled over for it being way too loud. But here's some pictures tell me what you think.
Old Apr 30, 2008 | 10:46 PM
cheeto's Avatar
has money, but unsure
unique
Old Apr 30, 2008 | 11:01 PM
t-rex04's Avatar
the second is mounted directly above the bottom one when the car's on the ground you can't see it. And i just noticed the pipes make a triangle shape
Old May 1, 2008 | 10:26 PM
Sargeant_002's Avatar
Cool - unique indeed - any chance of a dyno run - anything else done to your 8? A video clip on the way??? LOL
How much did this whole setup run?
Brian-
Old May 1, 2008 | 10:45 PM
I've been asking someone to do this set up for years.
Very nice.
How loud is it?
Old May 1, 2008 | 11:06 PM
Jon316G's Avatar
Grasshopper
I'm not a big fan of the kinks in the pipe... but I'm picky on appearance.
Are those "fins" around the tips? That doesn't look bad at all (but maybe a close-up pic would be better).
Old May 4, 2008 | 02:32 AM
t-rex04's Avatar
The small kinks in the pipes are a cosmetic downside. The tips are bevelled at a 45 degree angle and it does look like fins which is actually a cool idea (actuall it would tie nicely into the design of the headlights, but I like the tips I have), but their actually dimples in the tips as far as noise is concerned it actually gives a very deep hum but the db level i still have to check out. It can be loud if you bring it up over 4k which is almost always with a rotary. I'll be all set if it's 95db or less
Old May 13, 2008 | 10:39 AM
t-rex04's Avatar
Just bought a DB meter at 4k it tested roughly between 95DB and 96DB @ 6k the needle pinned on the DB meter I didn't change the range setting to see how loud 6K was yet but will play around with it more later.
Old May 13, 2008 | 12:30 PM
Renesis07's Avatar
Vtak just kicked in yo!!
I like it!! It will look a lot better once you drain the water out of you passenger side tail light
Old May 13, 2008 | 06:45 PM
Trekk's Avatar
Goat rider
Next time, (if there is ever a next time) you get an exhaust look for a shop that has a mandrel bending machine. Not that it will really matter much with an exhaust that big, but you keep the pipes from kinking down in spots.
Looks good though as long as you like it thats all that matters.
Old May 13, 2008 | 07:24 PM
FeelGuud's Avatar
looks good except for the kinks, but u wont see em unless the car is jacked up so ehhh. i would really love to hear how it sounds!
Hunterkelley24
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
