larger radiator / cooling
Old Nov 10, 2003 | 06:52 PM
Kas's Avatar
Kas
- Senior Menber -
Anyone know of any aftermarket radiators we can fit. I know there is alot of room, but something to bolt in would be great.
Also, as we aussies only got the 1 oil cooler, i'd be interested on a mazda price for these.
Seeing as alot of us will be going down the forced induction path, we cant expect this car not to overheat without using sifficient cooling.
Old Nov 12, 2003 | 01:54 PM
Turborex's Avatar
I think we should wait to see if we can even successfully run a turbo on this engine before we worry about it over heating. But as far as your cooling worries, a larger radiator would be a good idea, since the IC will go in front of the radiator. Also I think a second oil cooler could be thrown into the oil path no problem.
Old Nov 12, 2003 | 04:13 PM
Kas's Avatar
Kas
- Senior Menber -
is that a hint?
i'm pretty slow at getting hints.
Old Nov 12, 2003 | 07:22 PM
syntrix's Avatar
I like cheese!
Yeah, that's a hint, lol.
I can't believe that you guys only get 1 oil cooler. I've been thinking of summertime here in vegas when it's 110+ and any extra protection would be great.
However, if you go larger oil radiator, you do have to be careful. Engine operating temps could be lower than expected, and the car could be stuck in an eternal "warm up mode".
This is usually if you go extreme, and not if you slightly bigger. An oil temp gauge would be a great tool in monitoring current temps, and then seeing what a second oil radiator would do for you!
Old Nov 12, 2003 | 08:12 PM
Jason's Avatar
RX7store.net
I would guess that most of the aftermarket radiator companies like Fluidyne, Koyo and PWR will have a radiator out soon.
Old Nov 13, 2003 | 10:40 AM
Turborex's Avatar
Thats good advice syntrix.
Old Nov 13, 2003 | 12:07 PM
CWB's Avatar
CWB
I have two oil coolers. One on each side behind the fog lights.
Old Nov 13, 2003 | 04:39 PM
sco's Avatar
sco
Kas, there is a thread in the aussie forum about oil coolers around September, I think.
IIRC mazda price on extra oil cooler was $800 or so.
Old Nov 13, 2003 | 05:24 PM
Kas's Avatar
Kas
- Senior Menber -
as soon a smy car gets back i'll be looking at fitting a series 4 or 5 rx7 cooler. They are around $190 and my guess is they are about the same.
Old Dec 2, 2003 | 11:50 PM
mazdamac's Avatar
RX-8 performance radiator
AWR Racing has now come out with a competition radiator for the RX-8. AWR is the company that builds most of Mazda Motorsports' competition radiators. It bolts right in using all stock hoses and sensors.
www.awrracing.com/pages/store.html
Old Dec 3, 2003 | 03:45 AM
Efini 8's Avatar
no pistons!
someone already has done this. ARC (VERY EXPENSIVE) does a great job with their radiators and intake systems. High quality stuff from Japan.
Old Dec 3, 2003 | 03:51 AM
takahashi's Avatar
I heard the racing radiator works very well... certainly will be good to have a cooler engine. Don't you find the rotary engines are running too hot?
Old Jan 8, 2004 | 11:43 PM
JimW's Avatar
takahashi, only on the exhaust side, especially when the air/fuel ratio is leaned out. Believe it or not, unlike a conventional motor, I can run my RX8 very hard and go outside and touch the hood and it's cool to the touch!
Old Jan 12, 2004 | 08:42 AM
Jt-Imports's Avatar
Lots or radiators on the way..
I think they are waiting to see if the turbo kits hit or not.
200.mph
Dec 10, 2018 03:49 PM
olyrx7
Oct 26, 2015 09:23 AM
