10w7 or 10w6v2
Old Mar 27, 2008 | 06:09 PM
mpyfrom's Avatar
10w7 or 10w6v2
i am more interested in getting the 10w7 but have found a cheap w6v2. caqn someone please give me some input. will the single 10" w6v2 be enough or will i regret not getting the 10w7. will the 10w7 be too much, i like my ears and don't want to go deaf but like a hard hitting sub
Old Mar 27, 2008 | 06:12 PM
if you power the 10x6's properly and give them a good enclosure, they'll hit pretty damn hard
Old Mar 27, 2008 | 06:16 PM
mpyfrom's Avatar
i already got a jl 500/1 amp that i'm planning on using. also probably going to put them in a small ported box.
only running one sub - don't want 2
Old Mar 27, 2008 | 06:19 PM
I went with two JL10w6's and do thos badboys ever hit hard! I'm sure 1 would have been sufficient but figured if I was going to throw out the Bose system, I might as well go ALL out.
Not to hijack your thread but here's my stereo upgrade in case you're interested in persuing something similar. https://www.rx8club.com/series-i-interior-audio-electronics-24/jedis-bose-stereo-upgrade-103771/
Old Mar 27, 2008 | 06:24 PM
StealthTL's Avatar
Cool
DON'T use 10w7, it's too thin to protect the engine !!
S
Old Mar 27, 2008 | 06:25 PM
mpyfrom's Avatar
Nice! i would love to do something like that however i live out of the country and will prob sell the car in a year or two before going home. i'm just looking for something small that hits so i can easily take it out a put it in my car at home.
would basically like it loud enough to **** off neighbors
Old Mar 27, 2008 | 06:26 PM
mpyfrom's Avatar
S
what's too thin?
Old Mar 27, 2008 | 06:31 PM
get a box like the one I used, hook it up to the JL amp you already have, and begin pissing off the neighbors.
P.S. you'll need a line converter if you're tapping the rear bose speakers
Old Mar 27, 2008 | 06:33 PM
mpyfrom's Avatar
yea don't have the bose, should have mentioned earlier
Old Mar 27, 2008 | 09:25 PM
Why would you want to wake up the neighbors?
Old Mar 28, 2008 | 07:20 AM
cody6766's Avatar
I was changing subs every 6mos or so before I got my 10w7. 5 years or so later, I still have the same sub. I could have had the w6v2, but I would have moved on anyway...so I went big. I don't like to compromise sq though.
I've never auditioned the w6v2, so I'm not saying it's a no. It has great reviews and is priced a little lower, but it would always leave me wondering if I didn't have the best. The w7 is a heavy beast and needs a very solid box to avoid rattles, so be aware of that as well. Ported blows sealed out of the water with regards to both sq and spl if the box is built properly. I've tried several different configurations (none in the 8) and properly ported wins out every time.
Old Mar 28, 2008 | 08:09 AM
canaryrx8's Avatar
I disagree
Old Mar 28, 2008 | 08:22 AM
firebirdude's Avatar
User and Abuser
Originally Posted by mpyfrom
what's too thin?
It was a joke. As in "10w7" sounds like the viscosity of motor oil.
If you can get a deal on the W6v2, then I wouldn't even hesitate.
Old Mar 28, 2008 | 08:43 AM
RWagz's Avatar
Piston-free 07.11.2007
I'm going to disagree with you there as well. If you want a flat response (SQ), ported will not out-perform sealed, especially at port frequency. Below port frequency there is rarely any response.
Old Mar 28, 2008 | 11:39 AM
cody6766's Avatar
I was speaking of the w7 specifically, not in general. Also, by ported, I should have been more specific. I did not mean that any ported box at any tuning frequency would sound better than a sealed box. A low tuning frequency in a properly built box with the right volume gave me better sound in my GP. This was paired with a 3way comp set with 7's in the doors and mids/tweets in the kicks. The sealed boxes sounded nice, but lacked the impact across the board that the ported box gave. Since there is very little music below 30hz, a box tuned to 28hz doesn't leave you high and dry when the music drops. System tuning is important to make this work as well. I low passed my sub at 65hz with the midbass playing down to 40hz.
I had entirely different results with my former 15L7 and 10w0, but similar results with my IDQ15v2.
you can't just drop any sub in a ported box and expect it to perform well. It takes the right sub in the right box with the right system tuning for it to work. The blanket statement that ported boxes don't sound as good as sealed boxes is incorrect, but a good rule of thumb for a noob.
sorry for the essay...cary on.
oh, CA&E said that the w6v2 was the best sounding 12" sub they tested when it first came out. I don't think they put it up against its big brother at that point, but that's a good selling point IMO.
jpav123
9
May 27, 2010 12:10 AM
FastRX8
13
Oct 4, 2009 07:48 PM
Herblenny
Oct 23, 2007 02:20 PM
rotary9k
10
Jul 23, 2004 01:35 AM
