Short Q's about Int-X injectors staging
Old Mar 22, 2008 | 04:55 PM
funklove's Avatar
Eunos Cosmo T61
Hi all!
I have stock injectors on my SC RX8. The max boost is 8 psi. The max torque is at ~3500 RPM. The boost rises above 0 at 2000RPM on WOT.
1. I going to set up staging % to 70%, staging RPM at 2000, staging boost at 5Hg . Am I on the right way?
2. I try to explain. Fuel map shows 1ms pulse width for primaries. The real pulse width is 1.7 ms (+70%). Pulse width of secondaries is 0. Later RPM rises above 2000 RPM and a vacuum become below 5Hg (staging online). Primaries and secondaries run with 1 ms. Am I right?
Sorry for my English.
Thank you.
Old Mar 22, 2008 | 05:07 PM
From the Microtech site....this is what I understand about the staging setup in Microtech ECU...
this is not the IDLE/AUX setup that the IntX uses....INTx is set at 0% staging...and doesn't use it
If your below the Mapstage value..and above the RPMstage Value...You get primary injectors firing with %stage adjustment value
If your above both Mapstage and RPMstage ...you get Primaries and Secondaries firing at there set values
The %stage value has no effect after secondary injectors are turned on
The larger the difference between Pri and Sec injector sizes...the larger %stage value required to get smooth transition
Old Mar 22, 2008 | 05:19 PM
funklove's Avatar
Eunos Cosmo T61
Thank you! It's clear for me now.
Hunterkelley24
Jun 14, 2022 08:32 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
Evan Gray
Nov 24, 2015 01:00 AM
Jb4ker96
Sep 27, 2015 10:06 PM
