I got a CEL Code PO456. Any suggestions?
Old Mar 22, 2008 | 06:03 AM
BigWillieStyle's Avatar
Che is my BITCH!!!
I am looking for some suggestions from anyone who has received the CEL code before.
I went and had the code read and here is what the print out said...
Definition: EVAP small leak detected.
Explanation: The ECM has detedted a large leak in the EVAP system during a system monitor test.
Problem Causes:
1. Defective, loose or missing fuel cap.
2. EVAP canister broke, hose cracked or not connected.
3. Purge or vent solenoid defective.
4. Vacuum leak at engine.
Again any suggestions, ideas or help would be greatly appreciated!! Thanks All!!
Old Mar 22, 2008 | 06:25 AM
StealthTL's Avatar
You left your gas cap loose for two fill-ups.
Crank it till it clicks.
Dont worry, you are probably on an old version of the flash software for the computer - newer versions decrease the sensitivity for this alarm.
S
Old Mar 22, 2008 | 04:34 PM
Che is my BITCH!!!
I didn't think it was my gas cap, because I hadn't gotten a fuel fill up in about a week. Also, the gas cap was the first thing I checked and it was tight.
Do you think I may need to get the gas cap replaced? Or do you think I should get the comp a new flash?
Thanks Guys!
Old Mar 23, 2008 | 10:09 AM
VOODOO8's Avatar
Hermitage Holdout
Thanks Guys!
In the absence of any other type of guidance, starting a diagnostic loop with the cheapest thing that might need to get fixed and working your way up from there is usually a sound procedure to follow.
Old Mar 23, 2008 | 10:14 AM
expo1's Avatar
He's as bad as Can
Get a new gas cap, Stant part #10838. Fixes this issue almost all the time.
mdl0209
May 23, 2019 05:46 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
