Problem with intercept X on Greddy turbo
Old Mar 19, 2008 | 01:57 PM
qcheung's Avatar
LM-8
Hey guy, i just finish installing a Greddy turbo and i have a tuned intercept X with it.....But i just won't let me start the car...does anyone know wat happen...and how can i fix it? because when i unplug the intercept X, the car starts right away with the OEM ECU.....
Please HELP
Old Mar 19, 2008 | 02:39 PM
invasion08's Avatar
call scott at mazsport
Old Mar 21, 2008 | 09:42 PM
x-attack's Avatar
Did you remove the one way check valve that is right after your throttle bottle body where you took your vacuum signal for the int-x and all your other components (BOV, Boost gauge)? i believe its green and white!!
Old Mar 21, 2008 | 09:44 PM
mysql's Avatar
Doppelgänger
make sure the power cable for the int-x has the fuse properly installed and that it isn't blown.
Old Mar 21, 2008 | 09:59 PM
StealthTL's Avatar
Mysql seems to be right - do the Int-X LEDs light?
S
Old Mar 23, 2008 | 12:36 AM
qcheung's Avatar
LM-8
Yes, the light did came on....
Old Mar 23, 2008 | 10:03 AM
kersh4w's Avatar
Hit & Run Magnet
the fuse is blown. joo need another. possibly 2. so you can see if it happens again, and then try to diagnose the problem. then try again. maybe 3. :P
Old Mar 23, 2008 | 10:23 AM
Does it turn over?? Do you have upgraded injectors?? Do ou have it hooked up correctly? You need a Vac/boost signal to the unit for it to work.......start at the beginning and think through the whole install.
After that........is it flooded ( likely)
If it still doesn't start...give us a bit more information...
Old Mar 23, 2008 | 10:27 AM
Im_DANomite's Avatar
I love GOOOLD
i had the same problem when i had the Int-X. it would start with the OE PCM but not with the Int-X hooked up. make sure you have the right map loaded up.
i got the AP over the Int-X and it's awesome...
WranglerFan
Nov 5, 2017 09:35 AM
Randolph Alvarez
May 30, 2016 01:08 AM
ed0128
Sep 9, 2015 04:50 PM
