mounting trouble with emanage.
Old Mar 16, 2008 | 12:15 PM
gregs's Avatar
Pull My Finger
looking to mount and install my emanage ultimate i want to run the ultimate in the glove box, my question is does anyone have a picture i can use as a reference where to place the harness through the firewall? looks like the heater box is behind the glove box...pictures would help alot
thanks
greg
Old Mar 16, 2008 | 09:22 PM
first-rotary04's Avatar
wankel? what's that?
hahahah I'm in that same boat with you
don't where to mount it
Old Mar 17, 2008 | 07:22 AM
Phish806's Avatar
If you remove the washer fluid tank and pull back the insulation on the firewall you will see where the steering would have came through on a right hand drive car. This works perfect for making a hole to pass through there, there is enough space on the inside of the firewall where you will not drill into anything and it will pass out right behind the glove box. when feeding the wires from the engine to the interior you will need to direct the wires slightly downward and you will see them emerge into your floorboard. There is a pic somewhere on the boards. I think it was in a thread for routing the power wire for an amp.
Old Mar 17, 2008 | 10:36 AM
gregs's Avatar
Pull My Finger
thanks alot for the help!
Old Mar 17, 2008 | 11:48 AM
so i still have to drill it ??
I thought that there was gonna be a hole already made.
am i wrong ?
Old Mar 17, 2008 | 11:56 AM
staticlag's Avatar
The Professor
am i wrong ?
yup, you have to drill it.
Old Mar 17, 2008 | 12:01 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
I took a picture for you but forgot to upload it last night. It shows where to drill/cut the hole in the firewall. I will upload it tonight.
Old Mar 17, 2008 | 07:23 PM
tdiddy's Avatar
As promised. Pics of where I cut the hole for my EMU harness.
Attached Thumbnails mounting trouble with emanage.-3-9-08005.jpg   mounting trouble with emanage.-3-9-08006.jpg   mounting trouble with emanage.-3-9-08015.jpg
Old Mar 17, 2008 | 08:47 PM
gregs's Avatar
Pull My Finger
makes alot more sense thanks tdiddy
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
ShellDude
Oct 1, 2015 09:55 PM
pjwermuth
Sep 28, 2015 11:36 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
