HAWK HP+ Front/Rear Pads
Old Mar 15, 2008 | 08:40 AM
Spin9k's Avatar
Momentum Keeps Me Going
Used Hawk HP+ Pads -$40 shipped Cont USA - set of 8 pads for front and rear. That's only $10/per wheel!! Lots of useful pad material left - all pads with even wear .
{Price if new - Front: $79 Rear: $84 ... Total $163}
HAWK BRAKES Ferro-Carbon semi-metallic brake pad compounds offer high torque, low wear, and excellent rotor life, while exhibiting predictable performance under a wide range of temperatures. High Performance Plus Compound HP Plus - a more aggressive "streetable" brake compound that is ideal for Solo I and Autocross. The HP Plus material can take the heat at the track and get you home safely without having to change your brake pads after the event. This compound was designed for the serious street and autcross enthusiast. Temperature range - Up to 800F. Fits the larger sport brakes only (18" wheels)
Picyures note: rust is from moisture during storage in my gararge nothing to do with use - it'll disappear after first use.
Old Mar 16, 2008 | 05:41 PM
Spin9k's Avatar
BUMP - WHY PAY RETAIL - You can try these and see what Hawk pads are all about! These are not even 1/2 gone. BO they gotta go!
Old Mar 23, 2008 | 07:22 AM
Spin9k's Avatar
bump - price drop $40 plus shipping - this is giving them away guys. That's $10 a wheel and these pads have tons of material! I'm sure someone right now is forking over $150+ for these same pads to start the good weather season.
Where are you going to find anything this good for this nearly nuthin? (BTW the rust is from moisture during storage in my gararge nothing to do with use - it'll disappear after first use on you car).
These are acceptable track pads or daily use pads. They need to be put to good use by someone!!
Oct 3, 2015 09:51 AM
TheRedRotor
Sep 22, 2015 05:30 AM
airlive
Sep 7, 2015 08:32 PM
