Resetting Computer
Old Mar 1, 2008 | 05:48 PM
RatedX8's Avatar
Registered Car Nut
Question Resetting Computer
I've seen posts where people talk about resetting the cars computer after a performance mod (example: exhaust system). Why is it necessary to reset the computer and how is it done? I recently installed a catback system. Never reset anything on previous cars, what am I missing? Thanks in advance for feedback.....
Old Mar 1, 2008 | 07:52 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
There are two reset procedures, one for the NVRAM and the other for the KAM. Neither will erase your radio presets and such like the method SpooledUp7 posted:
1) With the key in the off position, press and hold the odometer reset button and turn the key to on;
Continue to hold the odo button until the odometer reads "TEST" and then release.
2) Turn the key to off and repeat step one.
This will reset the entire PCM except the KAM which contains the sensor profiles amongst other things. You can reset it with the familiar procedure:
1) Turn the key to on
2) Depress the brake pedal rapidly 20 times in a row until the oil pressure gauge sweeps to halfway and back again.
Posted by MM in a Search Result next time try and search these kind of things
Old Mar 1, 2008 | 08:19 PM
RatedX8's Avatar
Registered Car Nut
....appreciate it .....found it.........
Old Mar 2, 2008 | 03:38 AM
987HYS's Avatar
Dragon Certified
the RX8 has an intelligent computer system where it identifies the driving style of the driver and adapts engine management sytem to accomidate the users applications. when you add a performance mod, the reason most people reset the computer is for the car to re-learn the performance of the car and how it responds to driving conditions, and the overall performance of the car
Old Mar 2, 2008 | 04:29 AM
I'd advise you to learn how to use the search function or else ...
Old Mar 2, 2008 | 05:09 AM
DOMINION's Avatar
I don't buy Kool-Aid
^Ahh kity gon wap hem lol
Old Mar 3, 2008 | 11:09 AM
RatedX8's Avatar
Registered Car Nut
Thanks 987HYS...........You other two wise ****s.....save it.....cracks like that is what prevents this forum from being a tool for learning and sharing ideas.
Old Mar 3, 2008 | 10:51 PM
Is that what happened to all of Taj's bunnies?
cliffkemp
Dec 24, 2024 10:48 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
fistofmeat
Oct 7, 2016 12:15 PM
vapor2
Jul 9, 2016 07:35 AM
TheRedRotor
Sep 22, 2015 05:30 AM
