alarm that comes with the rx8, and after market remote start
Old Nov 3, 2003 | 05:16 PM
energie's Avatar
Hi there,
Does anyone know if it is possible to add a remote start module to our factory alarm?
en.
Old Nov 3, 2003 | 06:38 PM
RX-Nut's Avatar
8 the HARD way.
Inquiring Minds Want To Know. I'm curious too. I'm a newb to car alarms.. How does a remote engine start work for manual trannys.. especially for those who like to leave their car in 1st for "roll" protection?
Old Nov 3, 2003 | 07:07 PM
panda's Avatar
you have to bypass the clutch so that the car will start without the clutch being pressed, you will have to sacrifice parking in 1st because of this, and you can also hook it up to the handbrake so that it will not start unless the handbrake is up, and if it is let down the remote start will shut off, the same with the clutch being depressed, this is a very good security measure......
i hope i have it right!
andrew
Old Nov 3, 2003 | 07:15 PM
lunchbox348's Avatar
well for starters it is illegal to install a remote start in a car with a manuel tranny, on top of it is not recommended to install any after market parts on a car with a can network system
Old Nov 3, 2003 | 08:30 PM
harwax's Avatar
What is a "can network system" and 2nd question-can I have an aftermarket remote start installed on my automatic rx-8 and not void warranty. My dealer wants about $ 800.00 (he says he also has to upgrade alarm system).
Old Nov 3, 2003 | 09:44 PM
well a can system is like a network less wires more components
Old Nov 3, 2003 | 11:41 PM
Cwsmith's Avatar
Well it may be illgeal to install a starter in a manual car where you live but that is by no means true here in Canada, Walmart sells the units for self installation Nation wide. And you can go almost anywhere and have one installed for you, if you aren't hands-on.
Note: PANDA you are correct about the clutch and e-brake. the clutch is bypassed and the e-brake MUST be on and the car must be left in neutral.
Old Nov 4, 2003 | 01:27 AM
energie's Avatar
i was told by a few installer in Vancouver that installing remote start is illegal on manual cars. however with that said, once you get into the habit of putting it in neutral when parked, it is awesome.
i had it in my previous cars.
I am just curious, since our alarm is already quite good, i am hoping to get away with adding a remote start module to the existing alarm.
is that possible?
harwax, would you mind expanding more on the "can network" stuff?
thanks in advance!
Old Nov 4, 2003 | 06:23 AM
harwax's Avatar
Energie,
The person to ask is lunchbox348 (2 posts above my original post). I asked the same question.
Harwax
Old Nov 4, 2003 | 07:54 AM
well my advice is that if you are that unfamiliar with a cars system then i would not go messing with it. as for any ? on the can system go buy a shop manuel, and any good mazda tech will rip any after market item out if it is seen since mazda has a problem with aftermarket items.
Dokuji
Nov 1, 2016 02:51 PM
RXeckless
Aug 16, 2015 12:52 PM
T_Mags
Jul 24, 2015 11:29 AM
Jmanie9515
Jul 20, 2015 07:29 PM
RX7.9
Jul 20, 2015 12:01 PM
