Base map
Old Feb 24, 2008 | 07:00 PM
Gturbo8's Avatar
Base map
I need a base map for greddy emange ultimate: Anyone have it. My cars on the dyno right now really need a base map asap thanks.
Old Feb 24, 2008 | 07:05 PM
mysql's Avatar
Doppelgänger
http://rotaryinsider.com/files/TK_US_SE3P_RX8.EM2
Old Feb 24, 2008 | 07:06 PM
ChrisRX8PR's Avatar
13B-RE
Do you have stock injectors? Where do I email the map to? I have a few.
Chris
Old Feb 24, 2008 | 07:10 PM
Gturbo8's Avatar
Yea stock injectors My email address is rhettman001@yahoo.com thankyou
Old Feb 24, 2008 | 07:12 PM
Gturbo8's Avatar
Also anyone have the laptop software for the emanage ultimate
mysql's Avatar
Doppelgänger
The map I provided came from GReddy direct. It's the same map that ships locked on the EMU with the turbo kit.
Old Feb 24, 2008 | 07:19 PM
Gturbo8's Avatar
Thankyou I just need the software for my tuner
Old Feb 25, 2008 | 01:54 AM
Gturbo8's Avatar
ok got base map provided by mysql loaded onto the emanage. Changed spark plugs to all trailing ngk BUR9EQP8 with shims for the trailing plugs. Put hallman boost contoller on. Now when car goes into boost starts bogging and backfiring. Did have emanage disconnected from wiring harness to read serial number. Tuner checking connections right now(suspect pressure sensor connection). Tee'ed boost controller from wastegate to vaccum line coming off throttle body which also connects to bov, emanage pressure sensor, and boost guage sensor. Any ideas? I dont want my tuner to give up on it any help greatly appreciated.
Old Feb 25, 2008 | 02:22 AM
Gturbo8's Avatar
Ok my tuner figured it out. Seems that having the boost contoller on the same vaccum line as the pressure sensor was messing the signal up. Got it squared away but per advice from my tuner .4 bar is not enough!!!! How/where can i connect my boost contoller to. Were gonna try to connect it to the intake manifold nipple(s)(passenger side down by turbo) where is was originally connected to when it was just the wastegate to the nipple(s). Also we want to leave the emanage pressure sensor connected to the vfad vaccum fitting on throttle body. So need to reroute my bov and boost guage and possibly my boost contoller elsewhere. Those brave souls who have turboed there rx8's where do you have your bov, boost guage, boost contoller, and pressure sensor routed too?
yurcivicsux
192
Sep 12, 2017 10:54 PM
Paracleet
Feb 2, 2016 08:25 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Stubbs
Sep 27, 2015 04:06 PM
