no cat .....normal codes???
Old Feb 18, 2008 | 01:16 AM
chancejat's Avatar
Drive it like u stole it!
im running with no cat i always get p2096 and p0139....these are normal with no cat right? car runs fine has new coils and plugs and 33k miles....
Old Feb 18, 2008 | 01:28 AM
StealthTL's Avatar
Pretty normal....
Code list - https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
S
Old Feb 18, 2008 | 01:32 AM
chancejat's Avatar
thanks..i just wanted to make sure...the 2096 kind scared me...
Old Feb 18, 2008 | 02:01 AM
i am not running a cat right now and the only code i get is the 420.. been this way for a while..
did get a 171 code.. repaced coils, and fuel pump.. all is good..
so i would say address the codes you have as neither is aimed at the cat only..
Old Feb 18, 2008 | 02:13 AM
chancejat's Avatar
i also have a 02 dongle fooler....ill prob take it off bc it does nothing
Old Feb 18, 2008 | 02:17 AM
yep,
that would be a start..
pull it, then pull the room fuse..
and see where it goes... that would make sense with the codes.
Old Feb 18, 2008 | 02:24 AM
StealthTL's Avatar
Yes, a fooler is useless on the '8.
the 139 code is just the lack of readings from the rear O2 sensor, and one of the causes of the 2096 is listed as rear O2 sensor malfunction. Admittedly, it could be something else (check for a vacuum leak under the throttle body) but unless you put the cat back on, you'll never know.
S
Old Feb 18, 2008 | 02:29 AM
S
i did not know this was a trick ? am very curious about this now.
Old Feb 18, 2008 | 02:36 AM
StealthTL's Avatar
The 2096 code is actually "system too lean", so possibly an unmetered vacuum leak, and dangerous.
....but could also be caused by the dumb fooler circuit sending the same (lean) signal, all the time.
S
Old Feb 23, 2008 | 09:44 PM
DanRedRx8's Avatar
What a Nice Ass
i had a p0139 for a while and it was due to a clogged cat/ faulty joint gasket..... bought a new gasket and gutted the oem cat completley so i am running catless now.... all CEL's are gone
I dont understand why the p0139 would continue with a catless setup?
The code pretty tells you that there is abnormal flow going to the sensor.... it may be burned out... you can buy the sensor for about 100$ from one of the forum vendors and it is a breeze to replace.
Old Feb 23, 2008 | 09:59 PM
chancejat's Avatar
it was the fooler...i took it out when i got my second resonator welded in....now i just get a 0420
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
