Air fuel ratio
Old Feb 8, 2008 | 04:17 PM
DonaldNeo's Avatar
Air fuel ratio
Any advice on wat gadget to use to control air fuel ratio?
Will it helps performance and most importantly get better FC?
Old Feb 8, 2008 | 04:55 PM
Speedrx8er's Avatar
It will help you tune the car with the proper AFR and you will get more hp out of it.
Yes it is better to know your AFR with FC because it will give you an idea of how rich or lean your car is.. To lean and you could blow your engine.
Old Feb 8, 2008 | 05:03 PM
Brettus's Avatar
Boosted Kiwi
Check it out - a forum dedicated to the subject .
https://www.rx8club.com/series-i-engine-tuning-forum-63/
You can't improve much on FC because Mazda already did a good job with that .
Old Feb 8, 2008 | 05:15 PM
DonaldNeo's Avatar
What gadget to use?
My friend has an SAFC to tune his car's AFR
so does that work with our 8
or is there any other better gadget to use to control the AFR?
Is ScangaugeII able to monitor AFR?
If Scangauge is ablt to monitor AFR, can I use it to control or tune the AFR to our 8?
Old Feb 8, 2008 | 05:23 PM
Brettus's Avatar
Boosted Kiwi
Racing beat do a flash that leans things out a bit but you can't adjust it yourself with out an EMS - the forum I directed you to . Have a read
Yes scanguage can monitor AFR - but not adjust it .
Old Feb 9, 2008 | 08:16 AM
sammytcl's Avatar
SAFC does not work on rx8. If you want real time reliable and convenient monitoring of your afr, get a wide band o2 sensor & gauge, such as the innovate xd-16 stand alone kit. If you want to control or tune the afr, get an interceptor-x, or motec, or any stand alone ecu that's compatible with rx8. However, make sure you know what you are doing if you are tuning it yourself.
Old Feb 9, 2008 | 10:22 AM
Zero_Rotary's Avatar
Double 8
Howcome my scangauge doesnt show anything on AFR..u sure?
Old Feb 9, 2008 | 01:24 PM
Brettus's Avatar
Boosted Kiwi
actually no - I assumed it would be the same as Scanalyser and have this feature ........
Old Feb 10, 2008 | 02:31 AM
lennon's Avatar
ECU remap will be the best..... SAFC cannot work on RX8.....
Old Feb 10, 2008 | 01:06 PM
DonaldNeo's Avatar
I did ECU remapped by KnightSport did they lean the AFR a bit like Racing Beat does?
I heard of another gadget Blitz's I-fit or I-Vit that just need to plug it in like scangauge II that controls AFR. Does that work?
Anyway thx bros for all the advice.
Old Feb 10, 2008 | 01:13 PM
Brettus's Avatar
Boosted Kiwi
yes that would be what they did
I doubt it - what does the advertising say ?
Old Feb 10, 2008 | 07:54 PM
mkl22's Avatar
blitz i color flash does not control A/F ratios. its also does not display it. so far i know it only works for toyota MarkX and IS250.
Old Feb 11, 2008 | 01:46 AM
lennon's Avatar
You already did the remap, why still looking for other solution??
Old Feb 12, 2008 | 12:48 PM
DonaldNeo's Avatar
Looking for more control tats all
Anyway thanks for all your advice.
Old Feb 13, 2008 | 01:21 AM
coupe07's Avatar
SC 300HP!!
control over AF ratio u mean???
for more HP??
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
